Process to prep carbon fiber for paint? - Acura TSX Forum
post #1 of 5 (permalink) Old 08-04-2011, 03:56 PM Thread Starter
TSX owner
Hey guys,
I have a VIS RR hood and demon style trunk on the way. Going to have some custom paint work done on both. Anyone familiar with prepping carbon fiber for paint? Thanks
Sean
TSXiscoolikeice is offline
Sponsored Links
Advertisement
post #2 of 5 (permalink) Old 08-15-2011, 05:53 PM
bluecarbonfiber's Avatar
Send a message via AIM to bluecarbonfiber
epoxy can be wet sanded to get a sticking surface for the primer then after primer you can paint it.. any auto paint place should be familiar with it
Friends dont let friends drive stock..
PNW Acura facebook page, https://www.facebook.com/groups/1399402250271467
bluecarbonfiber is offline
post #3 of 5 (permalink) Old 09-26-2011, 09:49 PM
Greyout's Avatar
I'm not sure if this theory holds any water, but one guy who owned a body shop that did a lot of aftermarket work says that carbon fiber continues to cure in direct sunlight for a while. He suggested rocking bare carbon fiber for a few months, then getting it painted, it would have better results.
I have no idea if he is full of it.
Greyout is offline
post #4 of 5 (permalink) Old 09-27-2011, 11:06 AM
depending on epoxy used it could take up to 3 days to truly reach its full cure (if they got there mixture right) after that a wet sand with a 600 grit is fine if you are wanting to do a clear coat or 2 part mix paint. Ive been making carbon parts for the past few months and i am speaking from my own experience anyone who says the epoxy takes a long time to cure is either getting there mixture wrong or using the wrong stuff..
if they used Prepreg carbon (dry carbon setups) then it should be fully cured after getting out of the oven and cooling down.
the VIS stuff you have is cured by now by the time they made it and it reached you then it should be ready for prep and sand so you can paint it..
not sure if VIS clear coats there parts or uses just an epoxy that is uv resistant plus a epoxy clear coat on top.. that something you would have to ask them.. people who make parts have different methods so its good to know what was used on how it and how it was made..
post #5 of 5 (permalink) Old 09-30-2011, 12:14 PM
Post pics!!
Originally Posted by shoota
That video clearly shows that a FWD civic is superior to S2000 on the track.
wreak is offline
Sponsored Links
Advertisement
Tags
carbon fiber paint prep
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
