Serpentine belt change - Acura TSX Forum
post #1 of 11 (permalink) Old 12-21-2008, 01:35 PM Thread Starter
Ok, before I start, I have tried a search, but couldnt' find exactly the answer I was looking for.
I would like to change the belt on my car. I've found the tensioner, and I know what tool to use to loosen it, but my question is which part to loosen? As I look at it, there are two parts to the tensioner, the main body, and the outer wheel (the part which actually tensions the belt).
http://www.onlinewholesaleparts.com/hbt0001.html
Both seem to have bolts, but I'm not sure which one actually needs to be manipulated to loosen the belt. I don't want to strip the one that's not supposed to move.
Also, does the tensioner need to be changed at some point? I had a friend who's tensioner died, and now that I"m in the know about that as a possibility, I didn't know if that would be a potential maintenance issue.
Thanks for anyone's help.
dedeman is offline
Sponsored Links
Advertisement
post #2 of 11 (permalink) Old 12-21-2008, 02:41 PM
iVTEC no koe
HoRRo's Avatar
Pretty sure it's a 14mm bolt, here's the scans:
My car is stock, I promise.
HoRRo is offline
post #3 of 11 (permalink) Old 12-21-2008, 03:23 PM Thread Starter
Yep, you're right, 14mm. The damn autozone guy told me it was 15 (when I rented the kit), it had no 14mm bit, I have no 14mm bit (for some reason, but I have 10, 12, 13, 15)
Luckily, 9/16 is pretty close to 14mm, closer then 15mm is to the actual bolt. Too late I've already started to strip the tensioner bolt.
I may have answered my own question about replacing the belt tensioner. At least I have the scans to do that (thank you horro).
dedeman is offline
post #4 of 11 (permalink) Old 12-21-2008, 06:41 PM Thread Starter
While I'm on it, does anyone know how loose/tight the belt is supposed to be while the tensioner is torqued? I could only get the belt about 1/3 the way around the upper most thing (power steering?) around the belt, and not nearly enough to loop it around.
This was supposed to be easy....
dedeman is offline
post #5 of 11 (permalink) Old 12-27-2008, 11:11 AM Thread Starter
FINISHED
You must use a lowlowlow profile 14mm socket. The kit I rented did not have one, only 18, 16, and 15mm bits.
dedeman is offline
post #6 of 11 (permalink) Old 11-19-2014, 05:45 PM
Very good and*informative*exchange*..*Thank you!
Eddfetrwepol is offline
post #7 of 11 (permalink) Old 11-20-2014, 09:04 PM
Bardi
awoc's Avatar
Old thread, but to those wondering, I have one of these and works great!!!
Serpentine Belt Tool Kit
awoc is offline
post #8 of 11 (permalink) Old 01-24-2015, 02:25 PM
Save the manuals!
Good info as always AWOC!
This would come in handy doing a crank pulley or under drive pulley set - yes?
H22_J30_K24 is offline
post #9 of 11 (permalink) Old 01-24-2015, 09:26 PM
Bardi
awoc's Avatar
It's not strong enough for the crank pulley. This and a long 1/2" breaker bar will do the trick Honda/Acura Crankshaft Pulley Holder (7315) - Doughboys Tools & Equipment.
awoc is offline
post #10 of 11 (permalink) Old 05-23-2015, 04:09 PM
Newbie here and just used this thread to help change my belt. Thanks all.
Couple quick points
I used a 1/4" drive with a 14mm socket and just put the closed end of a longer open end wrench around the ratchet to get more leverage. Worked great. As we know the 3/8" is too fat.
..and like the pic shows, pull/push to the front of the car.
Thanks again all for the help.
J
TSex'r is offline
post #11 of 11 (permalink) Old 05-25-2015, 09:53 AM
What to put here...
Another trick, this one for getting the belt back on, is to route the belt around all of the pulleys with "lips" on the edges, and use the tensioner pulley (no lip / just smooth) as the last one. That way you can slip it on without needing to pull the tensioner pulley really REALLY hard/far.
SOLD - 2004 TSX, PWP on Ebony, 6MT, #00032. 2006 short block put in at 92,000km --> warranties are a good thing!.
Hondata, Tein, Koni, Injen, Unorthodox Racing, Comptech, Powerstop, FLP Maven, Japspeed.
NOW - 2014 Kia Optima SX-T turbo fun family hauler.
curls is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
