Originally Posted by spoonfed
Thanks for the info. If you or anyone can give some insight or examples on the best way to pop off the dash pieces that would be helpful. For example, pry from this side of the trim piece to release the clip. Something along those lines.
Yes all the trim pieces pops right out except for the door pieces which are held by 6-7 screws, so you need to remove the door panel. I just used a small flat screwdriver to pop the pieces out. Here's some illustration taken from Helms manual to get you some idea. Hope that helps.
