06-22-2009, 12:04 PM
#16 (permalink)
where can i find the ATF filter? can i locate it just right under the hood, or have to go under the car to locate it. i did my tranny fluid drain and refill twice last week...so do i have to drain the ATF in order to replace the filter?
07-09-2009, 10:45 PM
#17 (permalink)
USMC
My Ride: TSX / 2004 / Gray
I couldn't tell you for sure, i had a hard enough time finding the transmission.... true story...
07-11-2009, 11:52 AM
#18 (permalink)
http://tsxclub.com/forums/1st-gen-ca...ost391903.html
10-08-2009, 03:45 PM
#19 (permalink)
hey guys, i've got almost 74K on the TSX and I can feel the transmission kicking a bit more when it shifts (auto). Is there anyway to do a full flush without taking it to a mechanic? and if so, is it worth it?
2004 TSX Auto
2007 Xterra SE 4x4
10-08-2009, 08:29 PM
#20 (permalink)
I think Acura actually recommends against flushing the transmission. If you do 4x drain/fills with a few miles of highway driving in between each drain, you'll replace >90% of the fluid which is good enough
10-17-2009, 12:31 PM
#22 (permalink)
Hey there, nice pics of your filter. I want to adapt this filter to my civic, in the cooler line. I have the filter but there is no flow direction stamped on the filter. Do u have any idea which way the flow is? The filter has a crimp that is close to the inlet on one side as a reference point.
Thanks
11-09-2009, 07:18 PM
#23 (permalink)
I just went to the dealer today to pick up some tranny fluid and a washer. I also asked him about the filter and he said that there is no such thing. He said that Honda engines do not require one and he's a mechanic there. What's the deal with this elusive filter?
Lemonade was a popular drink and it still is
HONDATAfied AUTOmatically slow 06 rice rocket
11-13-2009, 02:53 PM
#24 (permalink)
same here, I need to do mine and mechanic said that the automatic tranny does't have filter which is why Acura recommended changing the oil at 30K. Can someone confirm this? not sure if the ATF filter is related to the transmission service.
12-07-2009, 10:04 PM
#25 (permalink)
- JDM TSX -
Nice write up. Any links where i could get that tranny fluid from. Can I get it from pep-boys or autozone ?
JDM TSX. N.W.G SOCIAL GROUP
CALLING ALL MEMBERS THAT ARE SLAMMED ! PLEASE JOIN
12-08-2009, 11:33 AM
#26 (permalink)
Donating TSXCLUB Member
ebay is best bet, these things use to be 3.75 a qt, now its up to 7.5 at dealers.. i bought 2 cases off ebay for around 6.5 shipped. Buy bulk
07 Z4
05 TSX
99 Accord V6
12-22-2009, 10:21 PM
#27 (permalink)
- JDM TSX -
Just recently changed mine with the same procedure.
| Thread Tools |
| Display Modes |
Linear Mode
