08-07-2009, 11:50 PM
#1 (permalink)
antifreeze flush
I have a 04 and would like to back flush the engine and radiator. I still have the older green antifreeze. Could anybody provide some insight as to how the back flush might be done?
08-10-2009, 09:02 PM
#2 (permalink)
My Ride: 2005 Acura TSX 6MT
You mean getting the rest out from the block?
There is a place on the block where you can drain it from. I am not exactly sure where it is, but it could be found with some research.
OR you can drain the radiator, fill it with water, run the engine for a bit, drain it and repeat a couple times.
lookin good, classy not hood
08-10-2009, 09:06 PM
#3 (permalink)
I pulled the top hose and ran water through the radiator til it came out clear. Damn flush machine broke at my job
08-11-2009, 06:40 AM
#4 (permalink)
There is an additional drain bolt on the block. It is located just above and to the left of the oil filter. It is the place to install a block heater. You can drain a bit more coolant from there
08-11-2009, 12:12 PM
#5 (permalink)
Bork Bork Bork
There is a plastic/white plug at the bottom of the radiator. No tools needed. Pretty easy to find too.
exterior:Tenzo DC5, blacked emblems, mugen grill, 25% tint, pwp hood trim, blacked calipers, front/rear A-Spec lip, 06 sides, spoon replica spoiler
performance & suspension: Apexi WS2 Catback, magnaflow cat, Ralco RZ pulleys, TS header (wrapped/sprayed) & vibrant flex pipe, cylinder resonator removal, mobile 1 synth, K&N drop-in, wicked tuning camber, h&r sport springs, koni yellow struts, comptech RSB, r1concept e-line rotors, akebono proact, DRH tb spacer
lighting & audio: Audi & blacked (housing) headlight mod, 5K low beams/HID fogs, smoked tails (spray), laminex, LED cabin, piaa reverse&license, aux link, 10" infinity sub, 1000w MTX amp, Polk DB651 (all doors), LED cupholder
08-12-2009, 12:12 PM
#6 (permalink)
antifreeze flush
Opening the drain plug at the bottom of the radiator will flush out antifreeze in the radiator only. How do you flush out the antifreeze in the engine block? Is there a easier way to completely flush out all the fluid from the system? Also, is tap water recommended for the flush, i.e. concerns from hard water deposits in the engine block? The Type II antifreeze comes 50/50premixed with de-mineralized water for that reason.
08-12-2009, 01:46 PM
#7 (permalink)
Bork Bork Bork
Just buy distilled water from the grocery store. It's pretty inexpensive.
I used Prestone antifreeze. It's not the Honda brand or color but I spoke with several mechanics who said it doesn't matter. It serves the same safe purpose.
| Thread Tools |
| Display Modes |
Linear Mode
