DIY: OEM LED 3rd Brake Light Conversion
27K views 30 replies 13 participants last post by  DeSEBticoN
#1 ·
These is the 3rd brake light we should have had. At least in the 2nd gens. So many other manufactures have LED 3rd brake lights, it's baffling why we didn't get one.
Background:
I wanted a full LED brake light setup for safety purposes and to look cool (duh). After going with Philips Vision LEDs for the main brake lights, I also tried their 7440 LED for the third (high-mount) brake light because all quality LEDs were too long. However, output was fairly dismal compared to stock during the day. I considered VLED V3 Tritons since the LED can be adjusted shallower. But I didn't want the fairly long and expensive Triton hanging down into my trunk space where I often throw in duffel bags and such. I then read that some Civic and Accord folks were swapping out their stock third brake light housing for the OEM LED one found in 2010+ Civic Hybrid models. Couldn't find any TSX owners who had done this so I documented the process so others may do what I did.
Parts needed:
1x 34270-SNC-A02 - High Mount Lamp
~$100, found here or the parts site of your choosing: HIGH MOUNT LAMP | Genuine Honda | 34270-SNC-A02
Note, make sure it's the "A02" and not the "A01", which is the older design with much more separation between the dots.
1x long skinny screwdriver
2-4x zipties
Depends on length but I used 3 because of the length.
1x needle-nosed pliers
Procedure:
1. Remove the bulb from the housing.
Inside the trunk, remove the bulb from the third brake light housing by rotating the connector counter clockwise.
2. Test the new housing.
Make sure it works before doing all this. Unclip the OEM harness from the bulb connector and plug it into the LED housing. Either have someone press on the brake pedal or do what did and stick something between the pedal and the seat. I used a short-ish umbrella. If it lights up, proceed!
3. Prepare the removal of the third brake light assembly from the top of the back seat.
This is easier than it seems. Inside the trunk, where the green circles are, you should see red and silver tabs in each area. Stick the screwdriver in and move/push the tabs kind of into the holes. There are 2 total.
By this point, the assembly should feel lose.
4. Remove the assembly.
Inside the cabin, behind the backseat, use your fingers to pry up the assembly. May take some finesse. It can be tight but it can come out.
5. Remove the stock bulb housing from the outer cover.
It's simply a process of popping out the tabs of the housing from the cover.
6. Install the new OEM LED housing onto the stock cover.
Comparing the two housings and the location of the tabs, you can see that the new housing will fit right in where the old one was.
If you look closely, you can see that some things are missing on the new housing. Namely, the silver tabs on the old housing, not circled. Those tabs are what you pushed back from inside the trunk with the screw driver. They are very important and they secure the housing down to the top of the trunk. It should be mentioned that when I was doing this, I didn't notice the new housing didn't have those tabs until I put in place on top of the trunk. The whole thing was very loose and insecure.
I considered superglue. Nah. I tried 3M double-sided tape (the gray stuff). Wasn't secure enough and looked weird. Good old zip-ties seemed like a good solution.
Piece together the zipties and put them between the cover and the new housing like so:
7. Install the new housing.
This part is a little tricky. From inside the cabin, while making sure the zip-ties are still on top of the LED housing, eventually "pulling down" on the housing to keep it in place, feed them through the holes that the silver tabs were in. See the picture in Step 3 for reference. I may have used the needle-nosed pliers at this point to grab them from inside the trunk. Pull the zip-ties through from inside the trunk and ensure the assembly itself is laying flat like the stock setup did from inside the cabin.
8. Secure the housing in place.
Connect the zip-ties together and tighten, but not over-tighten. Just until the assembly from inside of the cabin doesn't budge and the cover has very little if any gaps in the cabin.
9. Connect power to the housing.
Connect the plug from the stock harness into the LED housing again and you're in business!
Result:
A white/clear third brake light when off and when on you get OEM brightness and quality that performs better than any aftermarket LED.
Off
On
  • Like
Reactions: SharkCity_DRE
#2 ·
Some comparison shots:
OEM LED housing, Philips Vision 7440, stock:
I only took daylight shots because that's what matters most. I can take some a night shot if anyone's interested.
Philips Vision LED:
OEM filament bulb:
OEM LED housing:
#6 ·
It's compatible I believe, but that's the older model with the visible separation between the LED "dots", so I wouldn't recommend it. I used the newer one that blends the LEDs more. Make sure it has this part number: 34270-SNC-A02
Older one looks like this. Notice the 6 dots:
Newer one:
#7 ·
Damn i love you's guys!! (Pure platonicly, of course..!!) Great write up's and pics!! Mind if i hop aboard and "copy' your ideas?? (Ok, i wil do a little "different version"..) Already have idea(s), got to do some sketching...
Thanks guys, for the brainf**k!!
ACC-Man
#15 ·
Can anyone confirm that the "34270-SVA-A01" is compatible with our car? It really doesn't look like it would work, design/shape-wise, judging from pictures of it but I'm not sure if it can be done or not. Looks like the "34270-SNC-A01" AND "34270-SNC-A02" would work.
Everywhere I look it just says it's compatible only with coupe Civics.
#16 ·
#18 ·
I gathered together the LED's that i had flying around... always tend to buy things in 'uber' amounts.. just incase... what, I know not...
this is with a solid strip/cob pcb, led's about 4,5 cm apart, width is 3mm (You could place like 5-6 rows beside each other!!!):
this is a flex strip, waterproof, leds are red, 16mm apart, 1 cm wide:
this is a led bulb, t10 adapter, 4 leds unidirectional, 1 cm apart, 1 cm wide:
also an led bulb. Amber. 3 leds on tip, 20 around circumference. 2 cm dia, 3,5 cm long (Led area, not plug): (Too big I would say)
also a t10 bulb. Red. 4 leds on tip. 1 cm dia, 2 cm long (led area, not plug): (White would be better)
Single led bulb, colourchanging, prewired, 5 mm dia, 1,5 cm length. can be mounted in a screw-in mount. (White, non blinking would be better. using the mounts, you could install 40-50 in the housing):
I also thought about engraving the red plastic lens.. some saying/words/funny....
Let me play with that some more...
Mounty
P.S. For most of the single bulbs, you can install them in clusters.
for the strips, you could install a few side-by-side.. need not be waterproof/enclosed... for what??
#22 ·
Mounty
I actually just redid mine today. Did them a few years back. The strip was dried up.
Should have taken pictures. I mounted led strips facing the Chrome for even glow. Have TSX stencilled on the lens with red hi vis tape (brake light comes thru as TSX lettering)
#19 ·
Toyed around with the lens/housing.. did a couple of raw designs. like this one best, up till now: Drill 32 holes (8mm) to fit the single mounted led's: always varying between singles and pairs.. drew a quick design on the housing.. what do you think??
If I go this route, it will be white, non blinking bulbs...
ACC-Man
#20 ·
ACC-Man
I like it. Do you just happen to have an extra high-mount 3rd Brake Light laying around?
I'm interested in how it will turn out.
Phil
Sent from my iPhone using Tapatalk
#21 ·
Negative, Sir. It is/was installed in my car.
Being that i have a trunk mounted spoiler, with yet another brake light therein, it had been neutered.. rendered inop..
'Tis hidden behind tinted glass also, Sir
Just saw an offer on ebay.de/uk/com for 1k 3mm LED's/prewired, with threaded mounts for $26!!! do i really need 1k LED's?? YES!!
Can I use 1K LED's.... um, ......... hrmpf......
Actually, Phil, I am tinkering with the thought of going all out... I have a J's racing LED H Emblem on my trunk.. just needs wiring into the brake wires too... :
J's Racing The X'tream Honada Ride
and I was planning on adding LED strips to the lower (rear) reflectors aswell... all illegal of course... but would be controlled via switch(es)...
ACC-Man
#23 ·
This is what I was looking at/towards... the bezels are 6mm wide, so there is enough room to drill 2ea holes side by side, as I had thought/premeditated. The only 'problem' that may arise is that the bezels could be too long, towards the outer perimitter, figuring cables have to fit under there too.. (Taking 'pre-wired' leds, cause they already have the capacitor installed/soldered): (Did not buy them, as of yet.. still just 'playing/brain shopping'..)
Shopping Cart
...and perhaps 'engraving' something like this into the lens:
it's the Honda "Kanji"... Honda written in Nipponese.. You could go with something nice like: STOP
Or vulgar, like..... well, you know...
And if you were technically advised, as Aragrev7 is, then you could probably make/fit a 'running sign' into there with programmable words/letters..
http://www.flashingblinkylights.com/red-mini-scrolling-text-led-badges.html
or:
https://www.electronickits.com/mini-scrolling-led-sign-kit/ (7-9v only)
i have good ideas (i believe anyway), but he (Agarev7) knows what he's doing/talking about...
ACC-Man
... and if you really,, really want to make some impact/gain some (non) rep..., and never have to use your rear window and/or mirror ever again>>>>>>>>>>>THIS:
http://www.affordableled.com/f-2439-full-color-indoor-outdoor-programmable-message-sign.html
#24 · (Edited)
Today/this morning i further added to my tools collection. I bought an air compressor with a pile o tools, and a smallish sandblasting cabin with 3 different blasting mediums - Coke from a Smeltoven (Harsh - heavy removing), Glaspearls 0,5-1,2mm (Great for removing paint, matting the surface/no primer needed before paint/just a good cleaning) and a 25kg bag of walnutshells, also 0,8-2,0mm. (Ultra soft cleaning, takes quite some time, but it is the route with the least amount of material removal (ok, soda blasting is even softer, but makes a huge mess..). I am going to play around with some plexiglass.. do some 'glass milking/murking', like what agarev7 did.. I will keep you updated as soon as comp is here, up and running, tests performed..
AC-Man
I plugged 70 odd prewired led's into my breadboard, and fired it up.. Amperage draw was only 0,8 A!!! (5 rows of 10 leds, one extra row of 20 just to try..). My idea with 'writing' honda with leds would need approx 50 Leds.. 10 leds/letter. So, slowly working up an idea, plans a-k are still open.. a bit indecisive,, alas
#27 ·
Ok so my brackets are in and here are some pics , there is a additiona box inside that holds a strobing relay that flashes at same intervals as the brake bulbs in my tail lights. Wiring is custom made and everything is made to be direct fit plug and play. Also few shots of TSX housing for placement comparison.
