09-20-2006, 09:56 AM
#16 (permalink)
My Ride: Euro CL9 K24A3 6MT
If you every plan to use your audio system with the engine off, GO FOR THE OPTIMA or ODYSSEY! Yes, I am shouting. You can get the best normal sealed battery money can buy, but if it is not a deep discharge battery, it will die quickly once you run it below 50% capacity.
Optima 51R is discontinued for now, but you can fit a larger one in or go for the odyssey.
09-20-2006, 01:10 PM
#17 (permalink)
Which one is better? Optima or Odyssey, i have heard of optima and i know most people use it for audio upgrade. But what is odyssey? Never heard that one.
09-20-2006, 01:32 PM
#18 (permalink)
Premium Club Member
sometimes my car struggles to start..like it's dead..but other times its okay..
if i get the optima yellow top..i need a new battery tray for it?
Sorry Phase, I edit your post by accident. First day as a mod and I make a mistake. Sorry again. I have put back your original Question.
09-21-2006, 09:24 AM
#19 (permalink)
 Ex-Moderator Emeritus
Phase, The yellow top is discontinued because it wouldn't hold charge (or soemthing to that effect). I'm assuming that if you buy one now, it'll be a defective one and yeah, you'll need to make a battery tray. I think people have just not used the tray and made sure the battery was secured witht he tie down thing.
I went tot he CNE (City Fair) and saw an Enegizer booth. Apprantly Energizer makes a battery for the TSX but nowhere on the pamphlet does it have the specs of the battery.
Originally Posted by VorteC
09-21-2006, 11:34 PM
#20 (permalink)
http://www.odysseybatteries.com/
They are just as good, have a wider range of size applications and can be mounted on its side or upside down if you want. But Optima batteries look cooler.
09-21-2006, 11:37 PM
#21 (permalink)
Yellowtops are not discontinued. The only discontinued model is the D51 and D51R, which incidentally is the size for the TSX (and Mazda 121  ). Yes, they fail and they fail bad. One day it works, the next day it's gone. The spiral cell in it breaks from vibration because the battery is so small and the spiral plate assembly is thinner. My friend's D51R that was les than a year old just failed last week. So be warned.
If you use a D51R, you reuse your original battery tray. The reason why someone removed the tray or made a new one is because he had to use a larger sized battery since the D51R is not available anymore.
09-22-2006, 06:59 AM
#22 (permalink)
Thanks for the correction...i was thinking 'yellow top is discontinued for the TSX' but that's not what I typed hahaha.
04-06-2007, 02:26 PM
#23 (permalink)
whatever
www.1st-optima-batteries.com
so the Yellowtop D51 is still not available
Is "D75/25" the one to get ?
Who has this one ?
What do I need to do to make it fit ?
04-06-2007, 02:59 PM
#24 (permalink)
I'm here
Originally Posted by kyotousa
I am having problem with my battery
went dead twice already...had to jumpstart
my car is only 1 yr old...but Acura won't replace it.......
anyway.......are there any upside to change to redtop or yellow top? for regular user...
since I am not running anything extra....I am thinking if it dies again i'll just go to walmart to buy that 50dollars battery.....
What was the service departments reason for not replacing the battery?
01-28-2008, 10:20 AM
#25 (permalink)
Hi, sorry if this is in the wrong forum, but i was thinking battery is part of the engine so i posted here. I just want to know when should i replace my battery. TSX stock battery is not the best out there when comes to capacity wise. And lately when i turn on too much electronic gadgets the Nav will malfunction and not able to acquire gps signal. Also battery dies if i listen to music for like 30mins or so.
I also have harder timme starting, unlike when it is new, it will start just 1 crank, now i have to crank it longer.
btw, my car is at 65k miles and it is 2004/nav
Did replacing the battery fix your issue I am having the same problem along with the CD button doens't seem to work either.
01-28-2008, 02:08 PM
#26 (permalink)
Yellow top for the win, you can get it cheap at Costco!
You can lose a lot of money chasing women, but you can never lose women chasing money.
01-28-2008, 05:02 PM
#27 (permalink)
Retired
how much is it at costco buddha?
do you have the 75/25 (D35) or the 51R? I found the 51R on batteriesRus for 180 shipped, considering getting that but i'm having trouble finding them in store, that way i can recycle my current battery and possibly get some $$ for it
parting out! http://tsxclub.com/forums/tsx-classi...-part-out.html
2005 CGP AT w/ Navi
Audio | Hertz HSK165 Components | Hertz HCX165 Coaxials | Sundown SAX 100.4 | Sundown SAZ 1500D | Two - 10" SSA Icon D1 | Mercman's Harness & Balun | Dynamat Xtreme | Dice R4 w/ Text | Optima YT D35
Suspension | Progress Rear Sway | Neuspeed Strut | Buddy Club RSD Coilovers | Ingalls Rear Camber kit | Works VS-XX Hypersilver 18x7.5 +45 // 18x8+50 | Falken FK452 | Bridgestone RE960 | MOOG Endlinks | Hawk HPS | Brembo Blanks w/ X-Drill & Slotted |
Aero/Cosmetics | | Mugen Grill | JDM Hoodtrim | 20% Tints all around | Work Extended Blue Lugs | Mugen Emblem | Euro-R Front // A-spec Rear + Side Underspoilers| Window Trim DIY Blackout | Mugen Visors | Rear window spoiler | Painted IM Cover | Yakima Ski Rack |
Lighting | 05 FishDM Headlights | EDM Taillights w/ Foglights | 4300K HID Fogs | Polarg 6000k LED 194 Corners| PIAA 7440 Mirror Orange Turns
Performance | Hondata Reflash | NST Pulleys | Modded Comptech Icebox | Comptech Header | 06 Cat/Exhaust| TB Bypass
To come... | Refinish wheel lips & Powdercoat bronze
Bay area detailin holler at me!
01-28-2008, 05:38 PM
#28 (permalink)
Retired
nvermind, after seeing pix on the other battery thread, i just ordered a yellow top D35 180 shipped, pretty good deal. other place i found a 51R was for 175 shipped. 5$ more for a bigger battery, can't complain, and from the pix, it fits. touche!
2005 CGP AT w/ Navi
| Thread Tools |
| Display Modes |
Linear Mode
