Flywheel resurface. How much? - Acura TSX Forum
post #1 of 15 (permalink) Old 02-18-2010, 12:05 AM Thread Starter
I just picked up this k20a type r flywheel that I will be installing in my 6 speed along with an exedy stage 1 . I know that I will have to resurface it, but what amount should I tell the machine shop. I never had a flywheel resurfaced before since every time I bought a new clutch for any of my cars I always bought a new flywheel at the same time.
Here are the pics:
Thanks in advance
willyboyk24 is offline
Sponsored Links
Advertisement
post #2 of 15 (permalink) Old 02-18-2010, 04:39 AM
我々は火事を起こしませんでした
harmonichonda's Avatar
The shop who sees it in person can only tell you that. I just question why deal with used flywheels especially if they already need to be resurfaced. That's just me, have at it.
04 TSX - EBC5 series, ct-e icer, flp cat, ported IM, 68mm TB, e-throttle boost, ap2 tips
10 Accord - Takeda sri, ported IM, 68mm tb, weathertech visors, Nology Silver, Eibach, UR 19mm RSB, Sprint Throttle Boostin
harmonichonda is offline
post #3 of 15 (permalink) Old 02-18-2010, 06:38 AM
*Metalhead*
1TSXer's Avatar
I had a type-r flywheel in my Si. Before installing it, I paid about $55 to have it resurfaced. I think I paid about $75 for the flywheel itself.
2004 RYP S2000
Apexi VAFCII, K&N FIPK, Carbon Fiber Cooling Plate, PLM header, Berk HFC, Tanabe Medalion Touring exhaust, Swift Spec-R springs, Black Enkei RPF1's, 17x8/17x9, Dunlop Star Spec tires and black Work lugs.-220 tuned RWHP
2012 GM 370Z Touring/Sport w/Navi
K&N Typhoon intakes, Swift Spec-R springs, 20mm spacers all around
2010 CBP RDX
Hondata Reflashed
1TSXer is offline
post #4 of 15 (permalink) Old 02-18-2010, 12:18 PM
That's about right. A local shop wanted to charge me $50 for resurfacing
di2lude is offline
post #5 of 15 (permalink) Old 02-18-2010, 01:27 PM
a2dadamm's Avatar
i thouight the excedy clutch only worked with the hf02 flywheel.
thought i read that somewhere.
anyways. yeah about 50 bucks to resurface
a2dadamm is offline
post #6 of 15 (permalink) Old 02-18-2010, 02:02 PM
iVTEC no koe
HoRRo's Avatar
That's written on the Exedy website because TSX owners need to switch to a K20 (Type-S/R) flywheel. Since he has the OEM K20 one he doesn't need to use the HF02.
My car is stock, I promise.
HoRRo is offline
post #7 of 15 (permalink) Old 02-18-2010, 05:37 PM
我々は火事を起こしませんでした
Damn you guy are braver than me on used parts. Horrible lesson learned long time ago on flywheel reuse for me.
post #8 of 15 (permalink) Old 02-18-2010, 10:47 PM Thread Starter
A local shop here wants to charge me $40. They specialize in Flywheel resurfacing so I think I will be ok. I don't think I would resurface an aftermarket flywheel but since this unit is oem it gives some degree of confidence.
-a2dadamm, I got the k20 exedy stage 1 clutch to go with k20a flywheel.
-harmonichonda, what problems did you experience with resurfacing?
post #9 of 15 (permalink) Old 02-19-2010, 12:49 AM
Maybe warping. The flywheel could become out of round and imbalanced. That would be pretty bad on the crankshaft.
di2lude is offline
post #10 of 15 (permalink) Old 02-19-2010, 12:50 AM
Thanks in advance
Do you know if the flywheel has been machined before? If yes, you should likely toss it.
Machining a flywheel is just like machining rotors. The machine shop should measure it's thickness comparing that to the manufacturers mininimum thickness spec.
If it checks out initially, the shop will start machining it until the surface is perfect. They should take measurements between passes.
If it gets too thin, or is too thin after the machining, the rotor or the flywheel is tossed.
2006 PWP TSX, 6MT. Wifey's daily driver.
CT short shifter. Hondata reflash. RSX-S underdrive crank pulley. M3 lip, debadged.
DIY CAI/K&N filter. DIY exhaust (2nd resonator removed). Progress 22mm RSB.
CalgaryTSX is offline
post #11 of 15 (permalink) Old 02-19-2010, 02:52 AM
Turd Ferguson
cheezthis's Avatar
You can resurface and balance a flywheel as long as it's within the factory spec, which is in the service manual.
After years of aftermarket flywheels in my Integra, I'm going to back to a stock ITR...after resurfacing and balancing of course.
cheezthis is offline
post #12 of 15 (permalink) Old 02-19-2010, 04:31 AM
There are quite a few places in Orange County that will charge between $40-$60. I used to resurface S13 flywheels all the time when doing swaps for customers.
yonseispeed is offline
post #13 of 15 (permalink) Old 12-22-2011, 08:22 PM
Hey willy can u say how much the stock k20 type r flywheel weighed?
euro r is offline
post #14 of 15 (permalink) Old 12-22-2011, 10:39 PM
TOTM 2006
crix868's Avatar
I believe it's 10.5lbs but correc me of I'm wrong
December 2006 TSX of The Month -
2014 Nissan Pathfinder
2015 Toyota Camry SE
97 Integra 4DR - JDM H22 12.60s@112mph N/A (Sold)
05 TSX 6-Speed - Ferrari Red (Rosso Corsa)
crix868 is offline
post #15 of 15 (permalink) Old 12-23-2011, 02:22 AM Thread Starter
Wow back from the dead.
When I weighed it at work it was right around 11lbs
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
