Old 04-22-2005, 06:44 AM   #1 (permalink)
My Ride: Acura TSX 2005
rabbitman is neutral and has a clean balanced record.
Engine oil and ATF fluid intervals
The TSX manual says to change the engine oil every 10,000 miles, the oil filter every 20,000 miles and the ATF every 120,000 miles. These intervals seem way too long, especially for the oil filter -- does anyone have recommendations on intervals for fluid changes?
rabbitman is offline   Reply With Quote
Old 04-22-2005, 12:10 PM   #2 (permalink)
My Ride: Acura/TSX/2004
BBgun is neutral and has a clean balanced record.
for my car....6000km for oil same time filter, 50,000kilo for ATF....
BBgun is offline   Reply With Quote
Old 04-22-2005, 01:32 PM   #3 (permalink)
Donating TSXCLUB Member
Vegito's Avatar
My Ride: Acura/TSX/2005
Vegito is neutral and has a clean balanced record.
Both are cheap.. engine I would say 5-7k on mobil1, 3-4k on dino motor oil. ATF - 15k if you drive like a maniac, 25-30k if your granny shifting.
I dont think it's worth the effort to save and skip the filter, you should change it with the oil. If you are going to change the oil every 10k, at least change the filter every 5k
07 Z4
05 TSX
99 Accord V6
Vegito is offline   Reply With Quote
Old 04-22-2005, 02:26 PM   #4 (permalink)
TOTM 2005
SAZABI's Avatar
My Ride: TSX
SAZABI , with enough acceptance, will soon become famous.SAZABI , with enough acceptance, will soon become famous.SAZABI , with enough acceptance, will soon become famous.
engine oil 5000km
tranny 15000km
engine oil, use whatever u want, as long as it is the grade recommended on ur manual (in my case, it is 5W30)
for auto tranny, use Honda oil only.
June 2005 TSX of the Month
SAZABI is offline   Reply With Quote
Old 04-23-2005, 05:21 AM   #5 (permalink)
(8)
Ex-Administrator Emeritus
TOTM 2004
It all comes down to how you drive and how "much" effort you're willing to take to ensure maintenance levels are kept. The factory recommendations are simply recommendations, not mandatory/compulsory guidelines to follow.
