EDIT: Verified the bolts are 47 Ft/lbs
Page from physical FSM attached.
Original post:
The rear wheels were making an awful howling sound. The tires are loud RE11's but they just seemed too loud. After replacing the bearings, the sound went away, so I'm glad I held off on new tires. The hardest part was getting my long shaft torque wrench on the bearing bolts....that didn't sound right...anyway...
The FSM available online shows the torque spec for the four bearing bolts at a ridiculously low 16 ft. lbs. A couple friends that have Integras said that was probably wrong.
I read another post that said the FSM was wrong and they are 47 ft lbs.
Would someone please confirm the correct spec?
Thank you!
Original post:
Thank you!
