Weird Metal Grinding Noise While Driving - Acura TSX Forum
post #1 of 16 (permalink) Old 07-08-2008, 11:06 AM Thread Starter
anhster's Avatar
Question Weird Metal Grinding Noise While Driving
My car recently made this Weird Metal Grinding Noise While Driving. The noise is very noticable when i'm going above 40mph. It sounds like it's coming from the rear driver side wheel. Could it be that my pads are wearing out? rotor? Note: i've changed my brake pads that was purchased at an Acura dealership and had my rotor resurfaced in the front 2 months ago. The noise is pretty loud above 40mph so i can't tell if it's the front or back but i'm guessing it's the back becasue i had the front replaced 2 months ago. I have my windows up because it's embarassing hearing that awful noise while driving with the windows down. Any suggestions? HELP!!!
anhster is offline
Sponsored Links
Advertisement
post #2 of 16 (permalink) Old 07-08-2008, 11:51 AM
(9)
Moderator Emeritus
narci's Avatar
Rear pads will degrade twice as fast as the front ones so you might want to get that checked out.
Another things is you might have a seized caliper, your gonna have to get that checked out too.
Originally Posted by VorteC
narci is offline
post #3 of 16 (permalink) Old 07-08-2008, 12:02 PM
TOTM 2008
bluexcrush's Avatar
why does the rear degrade faster? is it due to the smaller pad surface? since the rear brakes do less braking than the fronts.
Thanks for voting guys!
bluexcrush is offline
post #4 of 16 (permalink) Old 07-08-2008, 01:04 PM Thread Starter
anhster's Avatar
I do n't know too much about cars, but you are saying that the pad could be warn out and the metal part is slighty touching the rotor? Correct me if i'm wrong!
anhster is offline
post #5 of 16 (permalink) Old 07-08-2008, 01:32 PM
(9)
Moderator Emeritus
narci's Avatar
Could be or the caliper is seized so that the pad constantly rubs against the rotor.
You won't know till you take the sheel off and inspect.
narci is offline
post #6 of 16 (permalink) Old 07-08-2008, 01:33 PM
(9)
Moderator Emeritus
narci's Avatar
No clue why..but I assume your right. Everyone has reported this from what i have read and it was same with myself too. I had 60% or so up front while my rear pads were gone..so i got them replaced.
narci is offline
post #7 of 16 (permalink) Old 07-09-2008, 05:00 PM
Varia's Avatar
Other way around... The fronts usually provide ~70% of total braking power. They get eaten up a lot faster than the rears.
Varia is offline
post #8 of 16 (permalink) Old 07-09-2008, 05:07 PM
RaCeR4LiFe022's Avatar
Send a message via AIM to RaCeR4LiFe022
Yeah thats how mine are..
06' TSX!
PWP
I was fortunate... JDM saved me... JDM rules everything around me now...
RaCeR4LiFe022 is offline
post #9 of 16 (permalink) Old 07-09-2008, 05:39 PM
(9)
Moderator Emeritus
narci's Avatar
Yes that is true..braking is mostly done with front brakes..but on the TSX, I believe the rear brake pads have less lining so they need to be replaced more often then the front.
Just do a search on the rear brakes and you'll see almost everyone will say they had to change thier rear pads before the front pads.
I know I did last year...original owner on the original pads..had to change the rear and front had at at least 60% left.
narci is offline
post #10 of 16 (permalink) Old 07-09-2008, 05:52 PM
Not sure if it is the same thing you heard but my 04 model was making a metallic grinding noise in its first year of life. Turns out it was the wheel bearing and it was replaced under warranty and the sound went away. Good luck!
TSX00 is offline
post #11 of 16 (permalink) Old 07-10-2008, 02:00 PM
(9)
Moderator Emeritus
endlesswinterco's Avatar
more then likely your brake pad indicator, letting you know your pads need to be replaced. the longer you let it go, the more likely you will need to replace your rotors too.
resigned from Mod duties....no time!
Currently:
2006 ABP
2011 CBP Tech Wagon
endlesswinterco is offline
post #12 of 16 (permalink) Old 07-10-2008, 04:14 PM
Retired Regional Meet Leader
pdpgps's Avatar
is this sound while braking or just normal driving?
'05 TSX
'07 RDX
'11 IS250
'13 ILX-Hybrid
pdpgps is offline
post #13 of 16 (permalink) Old 07-23-2008, 03:03 AM
kel1020's Avatar
i think i am having the same problem...how do i tell that it's in need of changing brake pad before i purchase one.... is it noticable visually???
kel1020 is offline
post #14 of 16 (permalink) Old 07-23-2008, 08:09 PM
Un-Civil Engineer
griffojm's Avatar
Its easier to see when you take off your wheel. There a post in the DIY section that shows how to remove the brake caliper to inspect the pads:
Click this link 2004-08 TSX Service Manual Scans - DIY then go to the brakes section. You should be able to see if the pad is wearing thin.
Good luck!
griffojm is offline
post #15 of 16 (permalink) Old 07-23-2008, 10:01 PM
wine em, dine em, cl9 em
plus.repped's Avatar
Send a message via AIM to plus.repped
this has never happened to my TSX, but something eerily similar would happen on my last car, 98 civic ex. it almost sounded like a pebble or rock got lodged between the pad and rotor... but i never saw any damage to the surface of the rotor and had recently had a brake job. it was the most unnerving, metal on metal grinding sound that would come and go. the sound would go away when i applied the brakes too. it was embarrassing when it did happen!
Certified Wheel Whore
FOREVER CLUB #2
IG @plus.repped
plus.repped is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
