Power Steering Leak - Acura TSX Forum
post #1 of 11 (permalink) Old 06-04-2009, 02:30 AM Thread Starter
I Heart my TSX !!!!
Send a message via MSN to 04TSX04
Power Steering Leak
Whats going on members,
I have a power steering leak and it is boggeling my mind, the boot that goes at the end of the tie rod end and the steering gearbox on the passanger side seems to have some power steering fluid that drips from the bottom of the boot,
I have checked all the power steering hoses and the boot on the end the the tie rod end and there are no holes or rips on the boot and the steering gearbox has no wet fluid on it either, so I know my steering gearbox seems to be fine, I don't know where the leaks are coming from, there are no leaks under the hood either.
any help would be appreciated
Thank you
04TSX04 is offline
Sponsored Links
Advertisement
post #2 of 11 (permalink) Old 06-04-2009, 04:28 AM
Lol my mechanic told me a story of this dude power steering leaking all in the booth. They couldn't find where all the liquid was going until by accident he touched the booth and it was hard. Not sure what was the problem if i remember ill let you know.
silver08tsx is offline
post #3 of 11 (permalink) Old 06-04-2009, 10:06 AM
I have the same problem. I'm taking my car in next week to local independent dealer that specializes in alignments. I went by Acura just to get an idea of the cost. Guy told me Rack and Pinion cost 1400.00 and that's without install labor. When fluid is leaking from the boot its common to replace the whole rack and pinion. Buddy of mine told me that I can get a refurbished one from Advanced for 330.00. I will keep you updated when I take it in next week. Hopefully they can just replace a seal and be done with this.
onebadtsx is offline
post #4 of 11 (permalink) Old 06-04-2009, 11:28 AM Thread Starter
I Heart my TSX !!!!
From what I can tell there is no hole in the boot, and no wet or fluid from the seal, that is what is boggeling my mind LOL.
and if it was the rack and pinion, would it be leaking from the driver side also ??
04TSX04 is offline
post #5 of 11 (permalink) Old 06-04-2009, 01:40 PM Thread Starter
I Heart my TSX !!!!
I called Bloomington Acura, In Minnesota, since Bismarck, ND does not have an Acura dealership ( yes its sucks LOL ),
I explained to the service manager what was going on, and he said its not very comon (SP) for the rack and pinion to go out in the TSX, unless he was feeding me a line of BS, I think I am going to just keep the PS resovour full, untill I can figure out the exact problem.
The good thing is it's not leaking alot, about a dime drop of PS fluid, I think I am just going to jack up my car, clean off the boot really good, start up the car and have a friend turn the wheel and see if I can find where the leak is coming from.
Thank for all the answers members !! I really appreciate it alot
04TSX04 is offline
post #6 of 11 (permalink) Old 06-04-2009, 02:45 PM
(9)
Moderator Emeritus
endlesswinterco's Avatar
posted on HT about this.
resigned from Mod duties....no time!
Currently:
2006 ABP
2011 CBP Tech Wagon
endlesswinterco is offline
post #7 of 11 (permalink) Old 06-04-2009, 03:07 PM Thread Starter
I Heart my TSX !!!!
Yes I did, just wanted to see if anyone here had the same problem or have a fix aswell, I will try your suggestion endlesswinterco tonight and let you know as soon as I find the answer, Thanks again I really appreciate it.
04TSX04 is offline
post #8 of 11 (permalink) Old 06-19-2009, 09:56 PM
*Metalhead*
1TSXer's Avatar
I had this same problem and took mine to the dealer. They said the rack needs to be replaced. $1,600 Bucks is what it's going to cost me! Mine was leaking from the boot that connects to the rack and pinion box on the driver's side.
2004 RYP S2000
Apexi VAFCII, K&N FIPK, Carbon Fiber Cooling Plate, PLM header, Berk HFC, Tanabe Medalion Touring exhaust, Swift Spec-R springs, Black Enkei RPF1's, 17x8/17x9, Dunlop Star Spec tires and black Work lugs.-220 tuned RWHP
2012 GM 370Z Touring/Sport w/Navi
K&N Typhoon intakes, Swift Spec-R springs, 20mm spacers all around
2010 CBP RDX
Hondata Reflashed
1TSXer is offline
post #9 of 11 (permalink) Old 06-20-2009, 02:38 PM
(9)
Moderator Emeritus
the boot isn't what is leaking, its a seal where the inner tie rod connects to the rack. the boot is just for protection from dust and dirt. Im pretty sure that 04tsx04 is going to try to replace just the seal. but im pretty sure the entire rack needs to be replaced.
post #10 of 11 (permalink) Old 06-20-2009, 03:00 PM
EuroRspec's Avatar
What's up with the 04s and steering racks. That should be Service Bulletin.
EuroRspec is offline
post #11 of 11 (permalink) Old 04-07-2012, 11:35 PM
04's and a bunch of problems.. ughh smh
wooosah is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
