Inner Tail Light Problem - Acura TSX Forum
post #1 of 9 (permalink) Old 07-08-2009, 03:58 PM Thread Starter
Freeeshhhh!
JDLST's Avatar
I have an 04 TSX and last night my passenger inner tail light went out, the reverse light still lights up when put into reverse but my inner tail light doesn't light up when i have my lights on. I thought it could be the bulb, and therefore i changed it. It didn't solve the problem. It seems that when i have the trunk open all the way up, the bulb lights up, but when the trunk is closed, the light will not light up. If anyone has an idea what is wrong, solutions will be greatly appreciated.
I suppose its a wire or harness problem? I just don't know where to start to look for the problem
"Whhhaaaaaaaaaaaaaaaaaaaaattt"
JDLST is offline
Sponsored Links
Advertisement
post #2 of 9 (permalink) Old 07-08-2009, 05:16 PM
Un-Civil Engineer
griffojm's Avatar
I would think it is a wire issue, where its separated when the trunk is closed and a complete circuit when the trunk is open. I would try tracing the wire to see if this is the case.
I am not a wiring guru though, so this is only a theory. Good luck!
griffojm is offline
post #3 of 9 (permalink) Old 07-08-2009, 05:30 PM
RML-R1
Regional Meet Leader
SF Bay Area
TOTM 2009
wong05tsx's Avatar
Send a message via AIM to wong05tsx
It should still light up when his trunk is open. The wires are ran along the left C shape hinge behind the plastic panel piece. Not too sure if this is much of help to you or not :\
Wheel gap is like a Vagina. The more fingers you can fit the worse off you are.
Audio | Hertz HSK165 6.5's w/ Rainbow SLC Tweeters | Hertz HCX165 Coaxials | Alpine PDX 1000.1 | Alpine PDX 100.4 | Two 8" Sundown Audio SA-8 D4 | Mercman's Harness | Dynamat Xtreme | Optima YT D35
Suspension/Chassis | | MOOG Endlinks | Hawk HPS | Brembo Blanks w/ X-Drill & Slotted | Tein CST | Progress Rear Sway
Aero/Cosmetics | | 20% Tints all around | Work Euroline SL | 06 EDM Headlights w/ USDM Projectors | EDM Tailights (Rear Fog) | A-spec Front & Rear Underspoiler | 05 Mugen Style Sideskirts | 5000k HID Fogs | Junction Produce| S2000 AP2 Exhaust Finishers
Performance | Hondata Reflash | TB Bypass | Injen CAI | 08 Cat
www.distinctivdetailing.com
Bay area detailin holler at me!
wong05tsx is offline
post #4 of 9 (permalink) Old 07-08-2009, 05:53 PM
(: Daniel :)
sortudo7's Avatar
Send a message via AIM to sortudo7
Sounds like a loose wire or connection somewhere. Just follow the wires as said and see if you have something loose somewhere. GL.
Sooooold
sortudo7 is offline
post #5 of 9 (permalink) Old 07-08-2009, 06:36 PM
+1 on this suggestion..it has worked for me in the past with other cars
2K6TSX is offline
post #6 of 9 (permalink) Old 07-09-2009, 02:01 AM
whatever
l7h8626's Avatar
exactly like my problem, except mine doesnt light up whether the trunk is opened or closed.
same side same light too. my driver side is good.
i traced the cables back to where it go into the frams that i have trouble to look over, no spots that caught my eyes. everything looked good :/
my solusion was to take off the driver side bulb. lol i know its not the best solution but at least my rear looks balanced at night.
since the outter lights are still working as parking lights and bright up when I brake.
please update if you find out what is the cause!!!! Thanks!
l7h8626 is offline
post #7 of 9 (permalink) Old 07-09-2009, 08:29 PM Thread Starter
Freeeshhhh!
JDLST's Avatar
update:
so yesterday i was looking for a solution to my problem. I couldnt find a solution. i did find a blue wire by the left trunk arm, that was ripped, so i spliced boths ends to wire em back together and it turned out to be my trunk light LMFAO!. Im sorry l7h8626 i could not find what was wrong. I am too afraid to take apart any wires haha, so i did what you did bro and took out both inner tail light bulbs. It will do for now until my dads friend, who is a mechanic can look at it. Ill update on the problem if i get it fixed. =]]
JDLST is offline
post #8 of 9 (permalink) Old 07-10-2009, 12:34 AM
whatever
l7h8626's Avatar
good to hear you fixed your trunk light....
l7h8626 is offline
post #9 of 9 (permalink) Old 07-10-2009, 04:52 AM
Lol
silver08tsx is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
