Rear inside brake caliper stuck - Uneven pad wear - Acura TSX Forum
post #1 of 29 (permalink) Old 12-29-2009, 02:28 AM Thread Starter
zildjonkim's Avatar
Send a message via AIM to zildjonkim
Hey everyone. I've got a 2008 TSX and with about 27,000 miles and recently my rear brakes have started to make a terrible screeching sound. It would be very inconsistent. Sometimes it occurs when I'm braking, other times it would just be during coasting or even accelerating.
Today I took off my rear brakes, first off, it was super tough to take off the caliper. I've worked with a bunch of other cars before, but this caliper was super tight. 2ndly, the inside brake pads are basically worn all the way down, but the outside pads are seeing normal wear. It seems to me that the inside pad/caliper is staying clamped even when i'm not braking, causing the uneven wear and the crazy screeching was from the pad being worn all the way down.
I've heard of people on these forums NEVER changing their rear pads or only after 100,000+ miles. To need to change my rear pads at 27,000 is ridiculous and the fact that it's got severe uneven wear between the inside and the outside pad has got me concerned. For now I've simply swapped the pads with new ones, but I'm gonna check back in a week to see if the problem still occurs.
Any ideas? Anybody else experience this before? If the problem persists, i'm gonna get it checked out by the dealership as it should be covered under warranty. Thanks in advance!
2008 NBP/ebony TSX
Euro R Lip Kit || Spoon Deck Spoiler || Tanabe Sustec Pro S-OC II Coilovers || Ingalls Rear Camber kit || Apex'i WS2 Exhaust || Comptech Icebox || Painted Grill - color matched nbp || 30/20 Tints
zildjonkim is offline
Sponsored Links
Advertisement
post #2 of 29 (permalink) Old 12-29-2009, 09:30 AM
iVTEC no koe
HoRRo's Avatar
Considering you probably don't have snow/salt in your area, it seems odd that your rear caliper could be seized due to weather conditions. Have you ever accidentally driven with your handbrake up? An overheated caliper could seize. Either way, the rear pads on the 1G TSX do wear faster than the fronts, so I'm not sure where you got that 100k rear pad life from.
At the end of the day though, if you're under warranty, Acura should replace the caliper for you unless there's damage there that they deem not under-warranty (caused by misuse).
My car is stock, I promise.
HoRRo is offline
post #3 of 29 (permalink) Old 12-29-2009, 09:47 AM
Is the car still under warranty of any type? If so bring it to a dealership and let them check it over
When I was a kid I used to pray every night for a new bicycle.
Then I realised God doesn’t work that way, so I stole
one and prayed for forgiveness.
slammedmind is offline
post #4 of 29 (permalink) Old 12-29-2009, 08:37 PM
USMC
newapocalypse's Avatar
I am at 84k and rear pads are still at above 25 percent... changed front a couple of times but way before time. You know there is something wrong by the simple fact that one pad is wearing way more than the other... Are you the only owner? (You never know what people will do before you)
newapocalypse is offline
post #5 of 29 (permalink) Old 12-29-2009, 11:48 PM Thread Starter
zildjonkim's Avatar
I am and have been the only owner. I guess we'll just see after a week and i check on my brakes again.
2008 NBP/ebony TSX
post #6 of 29 (permalink) Old 12-30-2009, 09:52 AM
What to put here...
Yeah the rear pads wear out at about a 2-to-1 rate compared to the fronts. I replace the rears every 18-24 months, and the fronts about every 48 months.
Get the caliper checked out (warranty) and be prepared to replace rear pads every other year.
SOLD - 2004 TSX, PWP on Ebony, 6MT, #00032. 2006 short block put in at 92,000km --> warranties are a good thing!.
Hondata, Tein, Koni, Injen, Unorthodox Racing, Comptech, Powerstop, FLP Maven, Japspeed.
NOW - 2014 Kia Optima SX-T turbo fun family hauler.
curls is offline
post #7 of 29 (permalink) Old 12-30-2009, 10:04 AM
USMC
Wow not at all... Specially considering the front pads+calipers provide 70-75 percent of the stopping power... You have it completelly backwards, front ones will wear out way before the rear ones...
In any event, back to the original issue, since you are still under warranty why dont you go and get some warranty work done and tell us whats up?
post #8 of 29 (permalink) Old 12-30-2009, 10:41 AM Thread Starter
zildjonkim's Avatar
I avoid the Dealership like it's the plague. I'm going to do some more testing on my own, then after getting a better understanding of it, I'll take it there. I bet for some stupid reason they'll pin it against my suspension or some other aftermarket part.
2008 NBP/ebony TSX
post #9 of 29 (permalink) Old 12-30-2009, 12:19 PM
(9)
Moderator Emeritus
endlesswinterco's Avatar
^ yes, they deff will say that because you are lowered and have aftermarket parts, that "causes" the pads to wear prematurely. i will bet alot of money they say that. my rears needed to be changed at about 40k. i did the fronts at the same time, but they weren't needed yet. Deff just keep an eye on it. you can get rebuilt calipers for the rear for about $100 or so. and its a pretty easy job.
resigned from Mod duties....no time!
Currently:
2006 ABP
2011 CBP Tech Wagon
endlesswinterco is offline
post #10 of 29 (permalink) Old 12-30-2009, 12:49 PM
What to put here...
Well when the front pads have about 40% more thickness to them, and the pads are wider (hence the "more stopping power"), you'd expect them to wear less than the rears.
Search here and on the other forum... it's VERY common that the fronts last almost 2x as long as the rears. I religulously maintain my brakes - servicing them every spring and fall, and with totally even pad wear between inside and outside pads, the rears still wear much faster (per set) than the fronts. It's due to the design of the pad (thinner / less 'meat') and the brake bias of the car (which seems to favour rear pads more than a typical car does).
curls is offline
post #11 of 29 (permalink) Old 12-30-2009, 02:19 PM
To the op, i dont know if you know that the rear brakes with built in parking brakes on the TSX you need the turn the caliper piston for it to go back inside. If you try to force it back in with out turning it, chances are you can mess up the whole rear brake caliper.
And yes the rears wears faster then the fronts on the tsx, i changed the rears before the fronts. I hope this help.
tsx07 is offline
post #12 of 29 (permalink) Old 12-30-2009, 06:20 PM
From my personnal experience with rear Honda disk.
The backplate(of the pad) need to be filed.
There is a big "burr" from the "shear effect" around where the pad will mate the SS Shim inside the carrier.
You want the pad to be free when you put them on the carrier.
If you use force(hammered them or whatever) there is a good chance that the pad, once you press the pedal that it will drag, hence, the difference in wear.
I give the back plate on both end, a nice "grind" so that when you put them on, they will "feel" like they will drop by themself.
Because of that, I never had problem with rear pad problem whatsoever.
It is true that if you were driving in salty roads, there would be a good chance that the rear caliper could be seized.
Since the back dosen't receive too much percentage of braking force, the caliper don't see too much heat and then, they rust!!
If you "bang" your pads to go in, sounds like there's the start of the problem.
francois is offline
post #13 of 29 (permalink) Old 12-30-2009, 07:03 PM Thread Starter
zildjonkim's Avatar
I didn't bang my pads to put them back in. I had used a tool to press the caliper piston back. Putting the caliper back on with new pads was super easy. Taking them off was a pain. Does anyone else experience that?
2008 NBP/ebony TSX
post #14 of 29 (permalink) Old 12-30-2009, 11:03 PM
Thumbs up
OEM Pads all need a grind and lube prior to install.
sparkie is offline
post #15 of 29 (permalink) Old 12-31-2009, 08:24 AM
aznboi0204's Avatar
This might be a little off but when I did the rotors for my car the calipers came right off and went right back on with little or no force
aznboi0204 is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
