Car won't start - Acura TSX Forum
post #1 of 11 (permalink) Old 01-11-2011, 08:29 PM Thread Starter
Kroost1's Avatar
Car won't start
Car would not start. I jump start the car but it would not work. went i try to start it all you hear is a clicking noise and it happens when i try to start it.
Kroost1 is offline
Sponsored Links
Advertisement
post #2 of 11 (permalink) Old 01-11-2011, 08:31 PM
Staff: Rank 2
Chief SuperModerator
Marketplace
Kevin's Avatar
battery is gone im guessing.
Kevin is offline
post #3 of 11 (permalink) Old 01-11-2011, 08:41 PM
i concur, sounds like your battery needs to be replaced.
anonymously113 is offline
post #4 of 11 (permalink) Old 01-11-2011, 09:34 PM
Staff: Rank 5
Moderator
Performance
tottenham12712's Avatar
Send a message via Skype™ to tottenham12712
yep yep, make sure anything in your car is off(lights, audio, a/c heat ect.) then jump it, if that doesnt work try a battery tender if that doesnt work its time to get the battery tested
tottenham12712 is offline
post #5 of 11 (permalink) Old 01-11-2011, 10:33 PM Thread Starter
Kroost1's Avatar
ya everything in my car works fine lights stereo everything else.. so how would battery tender work? i am thinking it might be the starter.. but then i am not sure..
Kroost1 is offline
post #6 of 11 (permalink) Old 01-11-2011, 10:34 PM
Premium Club Member
whatsanacura's Avatar
First check the battery as mentioned in the above posts. However, if your battery turns out to be fine, which could be possible since jump starting did not work, you may have a bad starter.
As I recall on my old Civic, the car also produced a clicking sound (but did not start) which in turn was coming from the starter that consequently had to be replaced.
whatsanacura is offline
post #7 of 11 (permalink) Old 01-11-2011, 10:43 PM
Premium Club Member
A battery tender just keeps the battery charge maxed but it's main use is for Boats/RV's/Stored Vehicles that sit for a while without being used hence the voltage is draining from the battery. You could try it but I would think that just getting the battery voltage tested and measured would be adequate to tell you whether your battery is dead/dying.
post #8 of 11 (permalink) Old 01-11-2011, 11:48 PM
Slow but turns
LeeMaster's Avatar
Send a message via MSN to LeeMaster
Double check and make sure your ECU hasnt gotten stolen. Happened to me once and when i found out about it i was like "WTF is an ECU?". hahaha i was a noob back then
LeeMaster is offline
post #9 of 11 (permalink) Old 01-11-2011, 11:55 PM
Staff: Rank 5
Moderator
Performance
a battery tender can recharge a battery if its dead, but if the battery was damaged it wont be able to charge it. just run to advanced auto or w.e you have around you and get the battery tested.
that "click" is the starter relay, if the battery is fine than when the relay clicks over and gives the starter juice, if your battery turns out ok you can try smacking the starter while someone turns the key.
also when you turn the key do your lights dim and flicker and weird stuff like that?
post #10 of 11 (permalink) Old 01-12-2011, 12:03 AM Thread Starter
Kroost1's Avatar
no actually the lights do not flicker.. but right before it didnt start every time i started my car it would delay the start. i am planning to switch batteries with another car and see what happens.
Kroost1 is offline
post #11 of 11 (permalink) Old 01-14-2011, 09:20 AM
trespassing Jeep owner
audioserf's Avatar
How exactly did your ECU get stolen? It's not exactly easy to get at. You can't steal it from outside of the car. I'm having trouble seeing how this is a thing.
audioserf is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
