Old 06-06-2005, 09:55 PM   #1 (permalink)
gman_in_NC
Guest
Posts: n/a
Question Popping Noise in Trunk area
GOOD NEWS, my problem has been repaired by the dealer in two days. It was considered a major body flex/stress noise. They removed the same things I did and more and repaired and rewelded strut towers, back deck and there was mention of cleaning off welds and sheet metal where painted together. All in all from what I was told 6 hours of difficult diagnosis and labor. Drove the car for the first time today without any popping noise coming from the rear. Also found this same problem listed on another forum and sounds like this is appearing across many models of Honda and Acura.
If you have the same problem, hit me with an email and I will give you the details on the repair order.
New owner with a weird problem. I have a popping noise in the rear of the vehicle back dash or trunk area. Sounds like a big drop of rain hit the trunk lid or a wire harness slapping the side of the fender. I have removed the rear seat, all the carpeting in the trunk the plastic wheel well covers, checked the trunk adjustment, removed the spare tire, checked the strut mounts you name it and still have the noise. Temperature makes no difference and it only does it a low speeds. Headed to the dealer next. My fear is that I have a poorly welded chassis or trunk brace and I am hearing stress in the vehicle which means it can not be repaired. Has anyone experienced this problem ?
Last edited by gman_in_NC; 06-16-2005 at 10:33 PM. Reason: My problem has been fixed others should know Reason: My problem has been fixed others should know
Old 06-06-2005, 10:07 PM   #2 (permalink)
The Bay State
APOGEE's Avatar
My Ride: Acura TSX 2004
APOGEE is neutral and has a clean balanced record.
Psydoc had a similar problem I think and it was a bad weld. I believe it was fixed under warranty and it is quiet now. Anyone else have any input on this mystery?
____________________
2004 Acura TSX ABP 6MT Non-Nav
APOGEE is offline   Reply With Quote
Old 06-19-2005, 01:39 AM   #3 (permalink)
lucky8's Avatar
My Ride: tsx/acura/2005
lucky8 is neutral and has a clean balanced record.
I have the same problem, when going at low speeds and pulling into a drivway or over speed bump the whole trunk area seems to have this loud creaking noise. I have about 500 more miles before my first servicing. I think i will have them look at it.
| 2005 | Navi | Carbon Grey / Ebony | 6 MT | OEM Body Kit | Spoiler | 20% tint | Blue LED interior lighting |
lucky8 is offline   Reply With Quote
Old 06-19-2005, 12:39 PM   #4 (permalink)
Padawan
aerozeta's Avatar
My Ride: Acura/TSX/2005
aerozeta is neutral and has a clean balanced record.
i hear the same thing, after i installed the cargo net anchors.....i guess the noise must have came through the lining inside the trunk.....
MOMO Air Leather shift knob
K&N air filter
OEM fog lights/hyper yellow
White LED front door lights
A-Spec suspension
A-Spec body kit
ACE Manta/hyper black
Yokohama AVS ES100
Trunk lip spoiler
Drilled/Slotted rotors
Axxis ceramic brake pads
aerozeta is offline   Reply With Quote
Old 06-22-2005, 10:11 PM   #5 (permalink)
gman_in_NC
Guest
Posts: n/a
Lucky8, better have them go over it. Mine was getting worse each day, lounder and more prevelant. I had to insist that it was a chasis problem and would not leave the dealer until a mechanic took it for a Road test. Believe it or not it was really acting up that day and he almost immediately told me I was correct with my diagnosis.
Old 07-03-2005, 11:22 PM   #6 (permalink)
jamesveale is neutral and has a clean balanced record.
I am hearing the same noise in my 05' TSX can you detail the repair order so I can communictae this to my dealer. Thanks!
jamesveale is offline   Reply With Quote
Old 07-04-2005, 03:48 AM   #7 (permalink)
aaron33's Avatar
My Ride: Euro CL9 K24A3 6MT
aaron33 is neutral and has a clean balanced record.
Hi! I'm new to this forums and I had this same problem. I'm located in Australia and I found the fix from another TSX site, and when I went to my dealer, they basically did the same fix.
There is a weld point in the rear parcel shelf. It's slightly to the left of where the left boot hinge goes in. If you look at the gap of the boot liner into the sheet metal area, you'll see a spot weld that is half on the top sheet and it holds the top to the bottom sheet. If you look at the same area on the right side, you'll see that the weld is fully on the top sheet, holding it to the bottom sheet.
With mine, they opened up the metal slightly (equivalent of massaging the metal to remove the stresses from the flex), and filled the gap with grease. I think it would be better if you filled the gap with epoxy, as that would help with rigidity (as the original spot weld was not "spot on" as to say).
aaron33 is offline   Reply With Quote
