Upgrade your rear brake for cheap $$$ - Acura TSX Forum
 2Likes
post #1 of 19 (permalink) Old 01-03-2017, 09:38 PM Thread Starter
lquebecois03's Avatar
Info Upgrade your rear brake for cheap $$$
Hey guys , I'll show you how to upgrade your rear brake by almost 1" the cheap way
Things you'll need :
-Rear brake disk from Honda Accord 08
>>>>-Rear caliper bracket from Honda Accord Hybrid 07 ( can be hard to find , but they're cheap )
-Rear brake pads from TSX 04-08
Difference will be : Rotor Diameter OEM : 10.225" , new size : 11.091"
This do not REQUIRES anything else beside some tools that you probably have
dinoc likes this.
lquebecois03 is offline
Sponsored Links
Advertisement
post #2 of 19 (permalink) Old 01-06-2017, 09:44 AM
J-Spec
Brock's Avatar
Honda didn't make a Hybrid Accord in 2008.
You're talking about a 05-07 Accord Hybrid.
You also need splash shields from the Accord Hybrid to properly complete the modification.
Brock is offline
post #3 of 19 (permalink) Old 01-06-2017, 10:07 AM Thread Starter
Yup I bought the rear braket from my friend at his junkyard and he told me these are from 08 accord hybrid but like you said they stopped in 07 and the model completely changed so my bad. I shouldn't trust a high guy in a junkyard sometime and verify my info. Thanks for the head up, I'll fix it !
But the disk from accord 08 will fit *
post #4 of 19 (permalink) Old 01-06-2017, 11:08 AM
J-Spec
Brock's Avatar
I'm guessing the Accord Hybrid brake rotors would work as well.
Too bad Honda doesn't sell the brackets separately.
Brock is offline
post #5 of 19 (permalink) Old 01-06-2017, 12:43 PM Thread Starter
No this is why it's cheap thought , I went to some place where they rebuild caliper and they had some but I got them for 10$ from the junkyard
post #6 of 19 (permalink) Old 01-07-2017, 12:51 AM
Interesting video and tutorial man. I would still much rather send my car to a shop though, I wouldn't trust myself to fix my car up to this extent just in case insurance might not cover the changes or if something happens with the connections after I'm done tinkering around with things!
webbrowan is offline
post #7 of 19 (permalink) Old 01-07-2017, 12:36 PM
dinoc's Avatar
Very interesting.
Also CU2 brakes upgrade could be an alternative.
[LE regarding CU2 brakes vs CL9]
CL9 front/rear discs size (300/260 mm)
CU2 front/rear discs size (320/305 mm)
also CU2 has dual pistons calipers and the front discs are much thicker
Info found on the EBC website (I hope it is accurate)
CU2/CL9 front discs
Vented Disc; 5 Bolt Holes; 320mm Diameter; 47mm Height; 32mm Thick; 30mm Minimum Thickness
Vented Disc; 5 Bolt Holes; 300mm Diameter; 47mm Height; 25mm Thick; 23mm Minimum Thickness
CU2/CL9 rear discs
Solid Disc; 5 Bolt Holes; 305mm Diameter; 57mm Height; 9mm Thick; 8mm Minimum Thickness
Solid Disc; 5 Bolt Holes; 260mm Diameter; 49mm Height; 10mm Thick; 8mm Minimum Thickness
'07 Euro Accord CL9 Type-S: Mugen Quick Shift, Alutec strut-bar, H&R front and rear anti-roll bars kit, A-Spec suspension, JDM Type-S front grille, Wavetrac LSD, FlashPro, littlebo's headers, Comptech Icebox, Hondata IM gasket, P2R IM gasket, J35 TB + larger TB to intake box pipe + IM port matched, Flashpro vittuned
dinoc is offline
post #8 of 19 (permalink) Old 01-07-2017, 04:04 PM Thread Starter
You'll need to change caliper for the front and what about the rear ? Yes , you can upgrade but this one is mostly for the look since it cheap. I doubt that the caliper fits with the handbrake all that stuff unless you did it and wanna share ?
post #9 of 19 (permalink) Old 01-08-2017, 05:54 PM
dinoc's Avatar
I know 2 guys did this swap, from CU2 to CL9 - I want it do it also, I'm looking for calipers.
It's a direct swap no alteration needed.
One of the guys has a topic on this here: https://hondakarma.com/threads/ichib...63/live?page=2
lol just for the look?? The front calipers are dual pistons vs single piston on CL9 ... did you read the above numbers to see the difference for front and rear, in size and thickness of the discs??
dinoc is offline
post #10 of 19 (permalink) Old 01-09-2017, 09:51 AM Thread Starter
Just for the look with my way* and cool I'm gonna take a look at his thread !
post #11 of 19 (permalink) Old 01-26-2017, 10:29 AM
Pretty sure cl9 front discs are 28mm thick, minimum 26 mm
Sent from my SM-G930V using Tapatalk
Coots is offline
post #12 of 19 (permalink) Old 04-10-2017, 12:41 AM
1flytsx's Avatar
I wish I could find a cheap set of brackets to do this....
1flytsx is offline
post #13 of 19 (permalink) Old 04-15-2017, 07:53 PM
All the pics are dead in that thread, any mor einfo on this conversion? Looking to upgrade my front and rear brakes
YYC_TSX is offline
post #14 of 19 (permalink) Old 04-18-2017, 04:12 PM
i have bracket to increase rear rotor size from stock to 305*9mm from acura rdx 07-11
Click image for larger version
ID:	34265   Click image for larger version
eugen19 is offline
post #15 of 19 (permalink) Old 04-18-2017, 11:58 PM
1flytsx's Avatar
do you know the part number of the bracket you used?
1flytsx is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
