Go Back   TSXClub.com Forums > Performance > Wheels & Alignment > 1st Gen - Wheels, ...
Old 11-10-2009, 03:42 PM   #16 (permalink)
cYn
Budget TSX
cYn's Avatar
My Ride: TSX/2007/CGP
cYn has a spectacular aura and a relevant respect from many.cYn has a spectacular aura and a relevant respect from many.cYn has a spectacular aura and a relevant respect from many.cYn has a spectacular aura and a relevant respect from many.cYn has a spectacular aura and a relevant respect from many.
yea dude. powdercoating one lug nut is nothing. but multiply it by twenty and then you got something.
cYn is offline   Reply With Quote
Old 11-16-2009, 11:53 PM   #17 (permalink)
My Ride: 1980/Hunter Chrysler/Red
PeteEvans is an unknown soldier, or on the road to either parallels.
Chrome Painting Procedure
Sand the chrome surface with 220-grit paper then wipe off the sanding dust with a clean cloth and lacquer thinner. Next, spray the surface with self-etching primer. Two coats will do. Allow to dry then spray two or three coats of a high build primer over it.
Once dry, spray light to medium coats of the paint which shouldn't run. Spray in spurts for better results. This will be followed with two to three coats of a clear coat finish which you should dry for 30 minutes.
Painting Riverside County
PeteEvans is offline   Reply With Quote
