Go Back   TSXClub.com Forums > Regional TSX Groups > Canada > Region 8Canada East
Old 09-14-2009, 02:57 AM   #1 (permalink)
My Ride: TSX/2006/Grey
manster555 is an unknown soldier, or on the road to either parallels.
Changing Rotors and Brake Pads
High guy i just bought 2006 grey tsx and needed to change the rotors and brake pads I'm looking for good rotors and brake pads i live in Mississauga my budget is around C$800 i can go a little bit over.
manster555 is offline   Reply With Quote
Old 09-14-2009, 04:15 AM   #2 (permalink)
My Ride: TSX/05/Silver
CraZie , with enough acceptance, will soon become famous.CraZie , with enough acceptance, will soon become famous.CraZie , with enough acceptance, will soon become famous.
Welcome. Use the search button for all the info you need. Look for rotors and pads. I' m pretty sure you'll find a vendor on here that sells both and reviews about each.
CraZie is online now   Reply With Quote
Old 09-14-2009, 09:51 AM   #3 (permalink)
My Ride: TSX/2004/5 Shades of PWP
scratchieepants has a spectacular aura and a relevant respect from many.scratchieepants has a spectacular aura and a relevant respect from many.scratchieepants has a spectacular aura and a relevant respect from many.
If you bought it recently, and you're thinking of replacing them already... why not ask the stealership to do it for free?
Acura of Woodbine flipped me the bird when I inquired about the TSX's brakes when I bought it.
Downtown Acura had no problems installing new brakes on my EL though.
Worth a shot if you just bought it.
scratchieepants is offline   Reply With Quote
Old 09-14-2009, 06:26 PM   #4 (permalink)
TSX Newb
My Ride: TSX/2006/NHBP
blackout5599 is an unknown soldier, or on the road to either parallels.
Agreed. I bought mine from East and they just replaced all the rotors and brake pads.
blackout5599 is online now   Reply With Quote
Old 09-14-2009, 07:18 PM   #5 (permalink)
the dealership gave me qoute of C$1400 for front
Old 09-14-2009, 07:48 PM   #6 (permalink)
Tell them to **** off and die.
I mean geez you can get superior aftermarket parts for front and rear for under $1000, and get someone like 360 to install for under $150.
If it's a certified pre-owned TSX, I think you should really pressure them to replace them for free, and remind them their conduct will determine whether or not you purchase another Honda product again.
Old 09-14-2009, 07:56 PM   #7 (permalink)
Not A MOD3RATOR
chuson's Avatar
My Ride: 2005 Acura TSX 5AT
Forget about stock pad, they are so weak compare to aftermarket.
Go contact HeeltoeAuto (our forum vendor), or anywhere. Get a nice set of Brembo/Mugen/ or any brand of rotor for around $200-300 (front pair); general use good brake pad are less than $150/pair from Hawks/EPC/ or Endless... they can stop way better than stock pad and has a higher resistant to brake fade in hot weather. Installation is cheap I bet anyone will do it for $60/4 corners.
Old 09-14-2009, 08:24 PM   #8 (permalink)
My Ride: TSX 2004 SSM
sparkie is neutral and has a clean balanced record.
I bought a set of front and rear cross drilled rotors that were plated in silver cadmium complete with a full set of F & R pads for $170.00 taxes incl from a place in Scarborough that also sells through ebay (seller name Silverstone). They have been on the car 6 months and not a speck of rust.
Installed all the parts myself in about 2 hours so my total cost was still $170
Last edited by sparkie; 09-14-2009 at 08:26 PM. Reason: added sentence Reason: added sentence
sparkie is offline   Reply With Quote
Old 09-15-2009, 02:36 PM   #9 (permalink)
My Ride: TSX/2005/White
Type-SR is neutral and has a clean balanced record.
I hope you get a whole car detailing and a happy ending for yourself as well.. what a rip !
Type-SR is offline   Reply With Quote
Old 09-15-2009, 03:06 PM   #10 (permalink)
bluefang08's Avatar
My Ride: Acura/TSX/04'
bluefang08 has a spectacular aura and a relevant respect from many.bluefang08 has a spectacular aura and a relevant respect from many.bluefang08 has a spectacular aura and a relevant respect from many.bluefang08 has a spectacular aura and a relevant respect from many.bluefang08 has a spectacular aura and a relevant respect from many.
$1400 is an INSANE ripoff...
bluefang08 is offline   Reply With Quote
Old 09-15-2009, 09:31 PM   #11 (permalink)
thanks guy's for all the replies i got a guy he's willing to change all four brake pads and rotors for C$120
Old 09-15-2009, 09:33 PM   #12 (permalink)
My Ride: Acura/TSX/2004
kycity is an unknown soldier, or on the road to either parallels.
If you drive your car anywhere from mild to hard I recommend RacingBrake slotted Rotors.
I go with EBC Greens for regular spirited driving. If you're lapping I'd use the Performance Friction 97 race compound. Expensive but kind on rotors. ($350CAD/pr.)
A lot of people here seem to like Hawks but their good sets tend to increase rotor wear if you drive hard. IMO
2004 TSX Non-Navi
Performance: Hondata, PNN4 Gearset +LSD, Injen, Comptech, T1R, Excedy, Corsport, Fastline
Handling & Braking: DSS, Koni Yellows, Eibach, Energy Suspension, Progress, Skunk2, Ingalls, Russell, Racing Brake, Power Slot, EBC, Yokohama
Lighting: 3000K HID Fogs, White LED Interior.
Misc: Dakota Digital, Switchblade, Blitzsafe, Optima
Cosmetics: None & None
Works done at: Import Performance Center – Brampton (Specializing in Honda & Acura)
Owners Name is Ken – Let him know you saw this shout-out from Peng on the TSXclub Forums!
kycity is offline   Reply With Quote
Old 09-15-2009, 09:58 PM   #13 (permalink)
Staff: Rank 5
Moderator
Marketplace
Pacemaker_Guy's Avatar
My Ride: 05 Auto ABP
Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.
For my front I have Brembo OEM blank rotors and Hawk HPS pads and for the rear Powerslot slotted rotors and Hawk HPS pads. The front cost me $300US and the rear was $270US. I did the work myself. Doing the brakes is super easy, just need the right tools and a plentiful amount of PB Blaster.
Palm Beach Hot Rods
Speed-Theory 973-227-2119
^Honda shop in Fairfield NJ
Pacemaker_Guy is offline   Reply With Quote
Old 09-16-2009, 02:10 PM   #14 (permalink)
where can i get those in canada or do i have order them from U.S.A
Old 09-19-2009, 05:46 PM   #15 (permalink)
I ordered them through Heeltoe here on the forums.
You can try JRP or Performance Improvements but you're going to pay a premium.
Remember to ship USPS only to avoid crazy brokerage fees.
Performance friction you'll only find from their authorized dealers.
2004 TSX Non-Navi
