Go Back   TSXClub.com Forums > Commercial Marketplace > Vendor Central > Excelerate Performance
Old 12-23-2008, 01:55 PM   #1 (permalink)
Forum Vendor
Forum Vendor
Excelerate's Avatar
My Ride: Multiple Honda's
Excelerate , with enough acceptance, will soon become famous.Excelerate , with enough acceptance, will soon become famous.Excelerate , with enough acceptance, will soon become famous.
STOPTECH Release Big Brake Kit for 09 TSX!!!!
STOPTECH FRONT BIG BRAKE KIT : 328 x 28 mm Rotor/ 4 Piston Caliper
Two Wheel Front Big Brake Kit Includes:
- 2 Piece Floating Directional 328x28mm AeroRotors
- 4 Piston ST-40 Calipers
- Stainless Steel Brake Lines (Front Only)
- Caliper Mounting Brackets
- Street Performance Pads (Front Only)
OPTIONAL:
Standard Caliper Color: Red or silver or black (30 days lead time)
Custom Caliper Color: Yellow, Blue, Gold (lead time of 60 days depending on application and $200 extra per caliper set)
Slotted or drilled rotor (add $100 for pair of drilled rotors); zinc coating ($70 for pair)
Acura TSX (09)
- Stoptech 2 Piece Front 328MM Slotted Disc w/ 4 Piston Caliper BBK - $1800 shipped to the cont US**
**Drilled disc add $100 per pair, zinc coating add $70 per pair
NOTE: Larger wheels may be necessary to accomodate space for larger caliper and rotor. Email me for info on how to check caliper clearance. Or you can go to www.stoptech.com and see how to check it.
Here is some important information on Stoptech’s BBK’s from www.stoptech.com:
Big Brake Kits give your vehicle that Supercar look and feel, and exceed stock performance in two areas. First, larger rotors increase heat capacity. Second, stiffer calipers and stainless steel lines reduce system compliance.
The key, however, is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio. If the brake upgrade you select adds too much front torque (as many do), you reduce your car's ability to utilize the tractive capacity of all of the tires to the maximum practical extent (even on ABS equipped cars) and you therefore create performance sacrifices. In addition, too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, which limits a driver's control of brake input on the race track.
Advantages of StopTech over other brake upgrades:
- Shorter Stopping Distances
- Better Brake Modulation
- Firmer Brake Pedal
- Less Brake Fade
Feature Benefit Summary:
- Balanced Brake Upgrades™ with optimum brake bias offer the shortest stopping distance with the best pedal feel
- Our patented AeroRotors® with the best airflow available result in better cooling, less fade and longer rotor and pad life
- The stiffest aftermarket calipers with patented bridge result in better clamping under hard braking and less pad taper
- Track testing of new applications ensures optimum performance
EXCELERATE PERFORMANCE - Official TSXClub Vendor and Acura Performance Parts Specialist!
See our Comptech, ROTORA, Unorthodox Racing, Progress, TOKICO, Innovative Mounts, AEM, P2R, KAIXEN HID, TEIN, Random Tech, Injen, DC Sports, K Sport, Ingalls Sales at The Excelerate Performance Forum
NEW WEB STORE: Store.ExceleratePerformance.com
AIM: Excelerate04 Phone: 203-483-6100
http://www.ExceleratePerformance.com
Excelerate is offline   Reply With Quote
Old 12-23-2008, 02:11 PM   #2 (permalink)
Darren's Avatar
My Ride: 2009 Acura TSX
Darren , with enough acceptance, will soon become famous.Darren , with enough acceptance, will soon become famous.Darren , with enough acceptance, will soon become famous.
Hot damn! These would look great behind my new 19" RonJon Legends!
Since the front rotor diameter is the same as the 1st gen (we know the 2nd gen has larger rear rotors) has it been determined yet whether or not this is exactly the same? Is the caliper in the same location and the mounting hardware the same? Because then we would know whether or not other kits like the Rotora kit are compatible.
'09 CBP TSX Premium AT
Aero Sport Kit, Paintmatched Front Grill, Rear Decklid Spoiler, 19"x8" Liquid Silver RonJon Legends, 245/35 Falken FK-452, Rotora Front Big Brake Kit, Eibach Pro-Kit, Project KICs R26 Black Chrome Lugs, 35% Tint, Debadged Rear, Removed Intake Resonator
Darren is offline   Reply With Quote
Old 12-23-2008, 03:33 PM   #3 (permalink)
The Red Wang
Back2Honda's Avatar
My Ride: 2005 Acura TLX
Back2Honda has a spectacular aura and a relevant respect from many.Back2Honda has a spectacular aura and a relevant respect from many.Back2Honda has a spectacular aura and a relevant respect from many.
I bought a set for a little less than that price from Josh for my TL. Solid product, best upgrade you can get for the brakes. The stopping power is incredible. Darren, if you get them, make sure you apply some sort of anti-squeal product or else it's going to squeal like a bat out of hell.
Back2Honda is offline   Reply With Quote
Old 12-23-2008, 04:48 PM   #4 (permalink)
Forum Vendor
Forum Vendor
Excelerate's Avatar
STOPTECH told me you can use the same template as the 04-08 TSX so I'm assuming at least the dimensions are the same.
