in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
Performance
Suspension / Chassis / Brakes
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
1st Gen - Suspension, ...
Dedicated to the Generation 1 (2003-2008) models.
30.7K
11.7M
6d ago
30.7K
11.7M
6d ago
2nd Gen - Suspension, ...
Dedicated to the Generation 2 (2009 and up) models.
1K
686K
Jul 22, 2023
1K
686K
Jul 22, 2023
Filters
Show:
Loading…
K
Just need confirmaton
kryngle
Feb 15, 2024
3
208
Feb 28, 2024
by
Matureaus
Y
Bleed Sequence Incorrect for Generation 2?
YoshiMoshi
Feb 23, 2024
1
156
Feb 23, 2024
by
Litespeed08
C
Engine mounts
ChrisCl7
Jan 12, 2024
4
223
Jan 12, 2024
by
ChrisCl7
Manual steering
Luck602
Nov 10, 2023
0
350
Nov 10, 2023
by
Luck602
R
Best Coilovers?
rydubz21
Oct 21, 2023
7
1K
Oct 23, 2023
by
H-dizzle
R
Tein CST Coilovers or similar suggestion
rindeuski
May 5, 2023
6
1K
Oct 23, 2023
by
PierceSchuman
Progress rear sway bar upgrade
skilledgreenurson
Jun 9, 2023
7
2K
Oct 22, 2023
by
PierceSchuman
4 piston RL advics calipers on 04 6MT?
skilledgreenurson
Aug 22, 2023
1
852
Aug 24, 2023
by
lordste
Greasing moog sway bar links…
arout707
May 17, 2023
4
930
Jul 16, 2023
by
joefischer1959
03-07 Accord rear rotors on 04 TSX?
skilledgreenurson
Jun 13, 2023
2
402
Jun 19, 2023
by
jhhhwood
Alignment after Bc coilovers installed???
arout707
May 26, 2023
2
499
May 31, 2023
by
arout707
M
Brakes grinding
mrzeetom
Apr 11, 2023
1
788
Apr 11, 2023
by
Litespeed08
Why am i getting noise from suspension on pitch holes?
bessiereedhot
Sep 23, 2022
3
1K
Dec 1, 2022
by
CraigDM
W
Suspension maintenance before installing coilovers?
watsx
Nov 29, 2022
0
1K
Nov 29, 2022
by
watsx
A
Spoon Rigid Collars
A2k.db8
Oct 25, 2022
2
1K
Nov 21, 2022
by
A2k.db8
C
07 TSX Suspension upgrade for wife.
CobraCommander
Sep 4, 2022
6
2K
Oct 26, 2022
by
Warder45
H
Little worried i wasted my money please help
Hgthurgood
Mar 14, 2021
9
2K
Oct 19, 2022
by
AmreDiora
G
Piece that fell while replacing rear caliper (TSX 2004)
george-tsx
Sep 17, 2022
2
1K
Sep 19, 2022
by
TeamPortuguese
Good cheap brakes
Steven.TSX
Sep 3, 2022
0
833
Sep 3, 2022
by
Steven.TSX
Truhart TH-H808 Install
Jimbop1209
Mar 27, 2022
2
2K
Jun 21, 2022
by
Jimbop1209
Rear control arms specs
Mcjello
Apr 17, 2021
1
2K
May 21, 2022
by
psychiatrie3emerot
T
Soft pedal, leaking master/booster?
Trevorjohn
Feb 11, 2022
2
2K
Feb 22, 2022
by
sonyfever
04-08 billet drop forks MPCmotorsports
GunnerbigMACK
Nov 25, 2021
0
2K
Nov 25, 2021
by
GunnerbigMACK
Suspension
Thatguy3288
Apr 11, 2021
11
2K
Apr 16, 2021
by
Thatguy3288
W
2006 tsx brake fluid change.
Wild Duk
Feb 28, 2021
2
3K
Mar 10, 2021
by
CG1120
Acura TL-S Brembo Caliper Swap?
White-Out
Oct 24, 2020
8
5K
Oct 25, 2020
by
Flamie
C
chassis?
chetan116
Sep 10, 2020
0
2K
Sep 10, 2020
by
chetan116
Plate behind break keeps rubbing
JojoElcatrin
Mar 7, 2020
1
1K
Mar 8, 2020
by
Litespeed08
31.9K
posts
12.4M
views
Coilovers, Struts, Springs, Chassis Bracing, Stabilizer Bars, Calipers, Brake Pads, etc.
Show Less
Join Community
Grow Your Business
Forum Staff
View All
obert
Administrator
Administrator
Administrator
Top Contributors this Month
View All
M
Matureaus
1 Reply
L
Litespeed08
1 Reply
Y
YoshiMoshi
1 Reply
Recommended Communities
AVS Forum
1M+ members
SkyscraperCity
880K+ members
Acura Integra Forum
2K+ members
Home
Forums
Performance
