2006 TSX Preventative Engine Maintenance Help - Acura TSX Forum
 3Likes
  • 1 Post By Edgeman
  • 1 Post By phen8tk
  • 1 Post By phen8tk
post #1 of 7 (permalink) Old 06-13-2018, 12:44 PM Thread Starter
Hey Guys,
Im going to try this again, since last time my thread didnt go through, maybe cause i attached a pic of my car...who knows LOL.
So I have a 2006 TSX 6 spd with around 173,XXX km and counting. I have been installing aftermarket parts for the engine/suspnesion/exhaust over the summer.
I wanted to do a preventative maintenance on my engine to reduce the chances of my engine blowing up or my TCT breaking. I have really bad OCD when it comes to maintenance with my vehicles.
Any tips or other things I should take a look at would be much appreciated. Currently what I have on my list are:
  • Fluid Flush (Brake, Coolant, Power Steering)
  • Spark Plugs
  • Cabin Air Filter
  • Serpentine Belt (Has a cold start squeek that goes away after it warms up, might be one of the bearings)
  • Timing Chain Tensioner
  • Valve Adjustment
  • Valve Cover Gaskets (What other gaskets should I replace while I have my Valve cover off?)
  • Spark Plugs
  • PCV Valve
  • Anything else i should add on to my list?
Thanks in advance everyone!
YYC_TSX is offline
Sponsored Links
Advertisement
post #2 of 7 (permalink) Old 06-16-2018, 06:13 PM
I would stick to the OEM maintenance schedule and if your drive your car harder then normal or put a lot of miles on it, you can move some of the services up. Good luck.
ebayking90 is offline
post #3 of 7 (permalink) Old 06-17-2018, 09:19 AM
The only think I can think to add to that list is maybe the PCV valve & engine air filter. I'm coming up on 90K miles, and plan to do most of what you have listed at that time.
I do my (brake, coolant, & power steering) fluid flushes on a calendar schedule, so they aren't on my mileage maintenance interval. You should flush your brake fluid every 2-3 years under normal driving conditions. I have an automatic transmission, so I do three "drain & fill" procedures at 30K mile intervals. I actually spread these over three oil changes. (My last were at 60K, 65K, & 70K miles)
When you pull your serpentine belt, spin all of the rollers to see if you can feel any that feel or sound differently when you spin them.
YYC_TSX likes this.
Edgeman is offline
post #4 of 7 (permalink) Old 06-17-2018, 11:48 AM
phen8tk's Avatar
If you haven't replaced the manual transmission fluid, might as well add that do the list. No need for a fluid flush for the transmission though, just a simple drain and refill.
Also, do yourself a favor and use the GM synchromesh or Redline MTF. You'll really like the improved shifting feel.
Since you're doing valve adjustment and TCT, opportunity for RSX-S VTC camshaft actuator swap?
YYC_TSX likes this.
2007 TSX 6MT CGP
Wheelwell Profile Link
phen8tk is offline
post #5 of 7 (permalink) Old 06-18-2018, 10:23 AM Thread Starter
Oh Ill add the PCV Valve on the list Thanks! Yeah might have to clean my Injen Filter.
Manual Trans Fluid was changed when i bought it 10k ago, Ill look into the VTC Camshaft Actuator swap, never heard of it before are there any benefits in doing this?
Thanks for the replies eveyrone
YYC_TSX is offline
post #6 of 7 (permalink) Old 06-18-2018, 03:59 PM
phen8tk's Avatar
The VTC swap will provide mid range gains in performance (~3k-5k rpm) by allowing more degrees of actuation for the intake cam. Stock VTC for 1st gen TSX goes to 25 degrees while the RSX Type S VTC goes up to 50 degrees. This mod is something that should be considered if you plan to get an intake and header.
Now that I think about it, this mod will be a real hassle. For the 06, it requires an ECU swap from an 07-08 model, a Flashpro, and a custom tune to take advantage of the new VTC.
YYC_TSX likes this.
2007 TSX 6MT CGP
phen8tk is offline
post #7 of 7 (permalink) Old 06-18-2018, 04:10 PM Thread Starter
Ill skip it i guess lol, this will be a mild build anyways just so i can keep myself occupied till the 2019 Supra comes out
YYC_TSX is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
You may post new threads
You may post replies
