Official Dyno Charts Thread - Page 4 - Acura TSX Forum
post #46 of 299 (permalink) Old 05-30-2010, 07:12 AM
Premium Club Member
PWPCL9's Avatar
Year / Transmission
04/6MT
Mods to engine and drivetrian
Injen intake,CT-E header,Fastline 2.5in testpipe,skunk2 exhaust,ingalls ETD,TB bypass
Supercharger / Turbo / Neither:
Neither
Engine Management or Reflash?
Reflash
Horsepower Peak @ RPM:
[email protected]
Torque Peak @ RPM:
[email protected]
Pic of chart:
_
ONE embed of YouTube of pull:
Login | Facebook
Shop name / Type of Dyno / Gear of Pull
autowerks in Richmond,Va/DYNOmite dyno/4th
Approx Temp / Altitude / Humidity
90 degrees+
PWPCL9 is offline
Sponsored Links
Advertisement
post #47 of 299 (permalink) Old 06-08-2010, 08:15 PM
Originally Posted by PWPCL9 View Post
Year / Transmission
04/6MT
Neither
Reflash
[email protected]
Torque Peak @ RPM:
[email protected]
Pic of chart:
_
Login | Facebook
90 degrees+
As "discussed" on your other thread, your results are a little higher than others with similar mods.
I have never heard of a Dynomite dyno, so I can't comment if they read a little higher like a Dynojet.
It's still possible that your engine just runs really well, but I would recommend another dyno at a different shop just to confirm.
Not trying to be negative, just logical.
2006 PWP TSX, 6MT. Wifey's daily driver.
CT short shifter. Hondata reflash. RSX-S underdrive crank pulley. M3 lip, debadged.
DIY CAI/K&N filter. DIY exhaust (both resonators removed). Progress 22mm RSB.
CalgaryTSX is offline
post #48 of 299 (permalink) Old 06-08-2010, 11:12 PM
Premium Club Member
PWPCL9's Avatar
Why am i getting all i did was get my car dynoed and posted the numbers... if you think their high I DONT CARE!!
PWPCL9 is offline
post #49 of 299 (permalink) Old 06-08-2010, 11:43 PM
I love my CL9!
willy18's Avatar
It's like posting up a picture of a super model and telling everyone she's your girlfriend. It might be true but some people just won't believe you. Just enjoy what you have and don't worry about what other people say.
willy18 is offline
post #50 of 299 (permalink) Old 06-09-2010, 11:26 AM
Send a message via MSN to scratchieepants
Anxiously waiting for willy18's dyno
Should push me towards going SC :P
scratchieepants is offline
post #51 of 299 (permalink) Old 06-21-2010, 06:43 AM
....its fate....
snYpz's Avatar
this is a n00b question, but with the dyno's that say that the results are measured at the flywheel, that would be different to whp? I would imagine that it doesnt take into account drive-train power loss?
<<<2008 NHBP 6MT >>>
Exterior: Modulo lip kit, Euro-R grille, Mugen grille, Mugen visors, Work VS-XX, Yokohama C-drive, Project KICs
Interior: Interior LED lights, Maven countersunk shift-knob, Bardi short-shifter
Suspension: Tein Flex, Ingalls camber arms, Alutece front strut, Progress rear swaybar,
IHE: CT-E icebox, 06 tsx tb, P2R TB spacer, RRC IM and cover, ASP header, FLP cat, 2.5" custom midpipe
Motor: RDX injectors, RBC VTC, Drag Cartel 2.2 cams, Supertech valvetrain, 09 tsx pistons, k20 oil pump
Transmission: K20a2 1st and 2nd with 4.7FD, wavetrac LSD, exedy stage 1 clutch, updated master cylinder, DC5-R flywheel
Tuning: 07 TSX ecu, Flashpro
Next...relip VS-XX and forced induction
snYpz is offline
post #52 of 299 (permalink) Old 06-24-2010, 01:07 PM
My car whines...alot
TOTM 2011
DAYTA's Avatar
Your assumption of differences between flywheel vs wheel horsepower is correct, however no chassis dyno actually measures at the flywheel despite what the dyno plot says.
The main difference of most output numbers would be between hp measured at the wheels on an inertia-load dyno (Dynojet) and hp measured at the hubs (Dynapack). In the case of at-the-hub measurements, the wheels are removed during the dyno process so rolling resistance is not accounted for in the power output.
DAYTA is offline
post #53 of 299 (permalink) Old 06-24-2010, 01:22 PM
TOTM 2011
DAYTA's Avatar
Year / Transmission:
2006 / 6MT
Mods to engine:
- CT supercharger (Eaton M62 @ 10psi)
- 3" PulleyBoys S/C pulley
- 08-09 Accord crank pulley (OEM)
- MercRacing aftercooler + heat exchanger
- custom XLR8 3" CAI
- HyTech long tube header (2.5" collector)
- custom XLR8 3" header-back single-exit exhaust
- Snow Performance Stage 2 water/methanol injection kit (w/ 625mL nozzle)
- Hondata IMG
Mods to drivetrain:
- ClutchMaster FX300 (carbon/kevlar clutch + heavy duty PP)
- JDM DC5 Type-R flywheel (10.25 lbs)
- Wavetrac LSD
Engine Management
Hondata K-Pro
349.6 @ 7500
Torque Peak @ RPM:
267.1 @ 5200
Pic of dyno plot:
**Click HERE for videos of dyno pulls and highway runs**
Shop name / Type of Dyno / Gear of Pull:
Innovative Motorworks / Dynapack / 4th
90F / 1000ft / 60-65%
DAYTA is offline
post #54 of 299 (permalink) Old 06-25-2010, 06:58 AM
....its fate....
snYpz's Avatar
^ congrats for the performance numbers and results on the car!
Must be a blast to drive!
thanks Dayta for the confirmation!
So you're saying that the dyno charts that have "flywheel ..." at the top of the graph, they are pretty much taking into account drivetrain loss, thus really measured the output at the wheels?
+1 rep (long overdue) - very knowledgeable regarding performance and great advice.
snYpz is offline
post #55 of 299 (permalink) Old 06-28-2010, 12:54 PM
TOTM 2011
DAYTA's Avatar
Really the only instance of output measured at the flywheel is on an engine dyno (i.e. if the engine is removed from the car and dynoed independently).
The majority of dynos available for use to the public are chassis dynos, so they all include drivetrain loss in their results. Again, "at the wheels" is a relative term since inertia load dynos (Dynojet) also incorporate variables such as the rolling resistance of your wheels. For example, running larger or heavier wheels with a higher degree of inertia would translate into more rolling resistance, and in turn affect your results on a Dynojet. In contrast, hydraulic load dynos (Dynapack) do not measure this variable because the dyno is mounted directly to the drive axles of your car.
In that sense, a Dynapack gives a more accurate representation of the power output of the engine itself whereas a Dynojet demonstrates how much of that power is actually making it to the ground.
...and thanks for the +rep .
DAYTA is offline
post #56 of 299 (permalink) Old 07-10-2010, 03:38 AM
TOTM 2009
Send a message via AIM to euro argh
ips kme cams, eibach valve springs, portflow retainer kit, kpro, rrc, 04 tb bored to 64 mm, weapon-r header, k&n cai, 2.5" magnaflow single exhaust, ur pulleys, exedy clutch/flywheel
YouTube - kme tsx
this is when they were tuning so it still sounds rough
i was there all day, too tired to take better pics/vids
2004 CGP
plus stuff
euro argh is offline
post #57 of 299 (permalink) Old 07-10-2010, 08:01 AM
....its fate....
snYpz's Avatar
^geez those are massive numbers running NA!
snYpz is offline
post #58 of 299 (permalink) Old 07-12-2010, 04:18 PM
TOTM 2009
thanks, i'm pretty happy w/ the results
2004 CGP
plus stuff
post #59 of 299 (permalink) Old 07-12-2010, 07:42 PM
....its fate....
snYpz's Avatar
Damn you better should be! lol
Those are great results, comparable to forced induction!
euro argh, whats your impression of the IPS cams?
I think i might just go with 06 intake cams, IPS literally costs an arm and a leg lol!!
Congratulations for the great result!
snYpz is offline
post #60 of 299 (permalink) Old 07-13-2010, 09:43 AM
littlebo's Avatar
YouTube - kme tsx
Its a grreat result for NA build , you picked up something like 90 hp, amazing ! Congrats !! You can beat any V6 now )) Hope to achieve something like 240 hp on my AT with nearly same setup.
littlebo is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
You may post new threads
You may post replies
