VSA Light Came on and does'nt respond to VSA Switch - Acura TSX Forum
post #1 of 23 (permalink) Old 06-26-2010, 10:14 PM Thread Starter
Paid 4
Hey whats up guys, my VSA Light and the "VSA trinagle sysmbol" just came on my 04 tsx, it doesnt turn off when I press the VSA Button, and its been on for about 2 weeks now. I even changed the VSA Switch, but it still stayed on, atleast I know its not the switch. Car still runs fine. Has anyone here had this problem, and how can I fix it.
craig.creationz is offline
Sponsored Links
Advertisement
post #2 of 23 (permalink) Old 06-26-2010, 10:24 PM
iVTEC no koe
HoRRo's Avatar
https://www.tsxclub.com/forums/1st-ge...-triangle.html
See if that works.
My car is stock, I promise.
HoRRo is offline
post #3 of 23 (permalink) Old 06-26-2010, 10:36 PM
Slow but turns
LeeMaster's Avatar
Send a message via MSN to LeeMaster
i just had that same problem starting today after i replaced that darn fuse that i blew up. except i had VSA/ABS/ and BRAKE
LeeMaster is offline
post #4 of 23 (permalink) Old 06-27-2010, 09:13 AM
What to put here...
Odds are its the brake switch. It's dirt cheap, so after checking the obvious (FUSES!), replace the brake switch with a new one (under $10) and you shoudl be good to go.
Warning: You might not have brake lights at the current time -- if not, you KNOW it's the brake switch.
SOLD - 2004 TSX, PWP on Ebony, 6MT, #00032. 2006 short block put in at 92,000km --> warranties are a good thing!.
Hondata, Tein, Koni, Injen, Unorthodox Racing, Comptech, Powerstop, FLP Maven, Japspeed.
NOW - 2014 Kia Optima SX-T turbo fun family hauler.
curls is offline
post #5 of 23 (permalink) Old 06-27-2010, 10:03 AM
Un-Civil Engineer
griffojm's Avatar
+1
I had the same issue. If you take it to the dealer, make sure they adjust the switch properly after installing it. Otherwise your cruise control won't work.
griffojm is offline
post #6 of 23 (permalink) Old 06-27-2010, 05:20 PM Thread Starter
Paid 4
Ok cool thanks guys, I'm gonna get a brake switch from the dealer tommorrow and install it. Will keep you guys updated.
post #7 of 23 (permalink) Old 06-27-2010, 10:47 PM
Donating TSXCLUB Member
Vegito's Avatar
Send a message via AIM to Vegito
I have that same/similar problem.. looks like our older cars are starting to develop problems.. how many miles do you have on it ? mine actually wont shift out of park
15 BMW M4
12 Lexus RX450H
07 Z4 3.0i
99 Accord V6 - Farewell 12.20.2013
05 TSX - Farewell 9.22.2012
Vegito is offline
post #8 of 23 (permalink) Old 06-28-2010, 10:42 AM
What to put here...
Just FYI, the switch from a Honda Accord (and probably all other Honda's of the same year) will work as well. If your Acura dealer doesn't have it, check with Honda. ALso if the Honda dealer is closer, all the better. Mine was from a Honda dealer and works just fine. They come from the same parts bin I assume...
curls is offline
post #9 of 23 (permalink) Old 06-29-2010, 09:43 PM Thread Starter
Paid 4
I have a 04 6 speed with 106k miles. I just bought the brake switch today, didnt get the time to put in in today though, so I'll pop it in tomorrow, will let you guys know the results.
post #10 of 23 (permalink) Old 07-03-2010, 01:44 AM Thread Starter
Paid 4
Ok I installed the Brake switch today, but the VSA Light is still on, Does anyone know how to reset the system so I can clear the code? Or do I need to take it to the dealer from them to clear it?
post #11 of 23 (permalink) Old 07-13-2010, 02:12 AM Thread Starter
Paid 4
I still havent gotten a chance to go to the dealer to reset the VSA as yet, but I did find this info below on acura zine on how to reset it, but does anyone on here know which pin is the 9th one??????????????????
I have fixed the problem myself without Dealer Scanner!
First of all you need to clear abs errors (that is the main problem why i have failed earlier).
1) Make a shortcut between 4 pin and 9th
2) Press with your foot on the brake pedal and switch on the ignition.
3) Wait for the ABS lamp to turn off and then remove your foot from the brake pedal.
4) Wait for the ABS lamp to turn on and press with your foot on the brake pedal again.
5) ABS lamp should turn off, then remove your foot from the brake pedal.
6) Wait for two flashes of ABS lamp. If it flashes it means that errors are erased.
Check the errors, not removing the shortcut - just turn the ignition on, if ABS lamp do not flashes, so no errors are in memory.
Now the main part.
VSA Neutral position setting
Do not touch the brake pedal anymore.
1) Make a shortcut of 9th pin to chassis (i have used a bolt on a door hinge )
2) Turn the ignition on, after ABS lamp turns off, shortly press the "VSA off" button
3) After ABS lamp turns on again, shortly press the "VSA off" button.
4) Now shoud be a lot of different blinks and fashes and all lamps ABS, VSA and triangle should turn off. The problems solved.
5) Open the beer bottle!
post #12 of 23 (permalink) Old 06-24-2011, 06:51 AM
g0t TSX?
YaNcY's Avatar
hmm
Questions...dont really want to bring up an old thread....but
My ABS/VSA/Triangle came up the other day, im worried. It went on out of nowhere...Turned off the car, it went away but then came on after i started to drive and then i braked and felt my abs kicking in and then went away and thats when lights came back on. The lights stay on for sure.
My Cruise control works, Brake lights Work...I just dont know what is the issue. VSA regulator?? lots of $$$...brake switch? is that a possibitly for all three lights go on?
LMK help, thanks.
Also I do have to check speed sensors? if thats a possibility i was told...But thats very odd. I
YaNcY is offline
post #13 of 23 (permalink) Old 06-24-2011, 09:36 PM
" It Is What It Is "
tsx4life's Avatar
Send a message via AIM to tsx4life
dude...i allready told you what it can be...i tell you becuase i went thru a situation with my abs/vsa not working ....
" I Love JDM "
" Haters Keep em' Coming "
....lol...
tsx4life is offline
post #14 of 23 (permalink) Old 06-27-2011, 01:38 AM
still in the game...
TOTM 2011
sickassly's Avatar
lol
sickassly is offline
post #15 of 23 (permalink) Old 07-03-2011, 03:46 AM Thread Starter
Paid 4
Problem Solved, I just used my friend computer to reprogram the vsa, and the light turned off, been about 6 months now, and the vsa works only when i press the button. So all you guys need to do is take it to a mechanic or dealer who has a computer than can reset it, and you should be good to go.
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
You may post new threads
You may post replies
