Hiccuping in low gears - Acura TSX Forum
post #1 of 3 (permalink) Old 12-21-2018, 09:28 AM Thread Starter
Hello,
I cannot figure out this issue i'm having with my 05 tsx 6spd MT
The issue is when I let go of the gas (as slow and smooth as possible) I get a hiccup, and when I come back on the gas, I get the same hiccup. It happens mostly on low gears 1-3, and it doesn't happen all the time.
I also see the needle on the speedometer hiccup as well.
jtruong95 is offline
Sponsored Links
Advertisement
post #2 of 3 (permalink) Old 12-21-2018, 01:31 PM
is it the movement of the engine or does it feel like a throttle issue? The TSX engine does seem to move and rock a lot and maybe your mounts are bad and starting to show.
socalcl9 is offline
post #3 of 3 (permalink) Old 12-21-2018, 03:59 PM
sea foam the vacuum system and fuel system via tank, check the air filter - reset the ecm after 50 miles, if it's still doing it check the cat, then the various sensors on the engine.
circuitsports is offline
Sponsored Links
Advertisement
Tags
hiccup, issue, low gears
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
You may post new threads
You may post replies
