2nd and 3ed gear grind - Acura TSX Forum
post #1 of 5 (permalink) Old 05-01-2019, 06:26 PM Thread Starter
Asanch23's Avatar
I have a 2004 tsx
Long story short my second and third gear were grinding so I switched out the master cylinder and the slave and put a new clutch in and blood the clutch line and put new tranny fluid in but it still grinds not as bad tho but still grinds does this mean that the synchros are bad??
Asanch23 is offline
Sponsored Links
Advertisement
post #2 of 5 (permalink) Old 05-01-2019, 08:49 PM
2nd and 3rd gear grind
Have you tried adjusting your clutch pedal/CMC? If that's not it then it's synchros and/or sleeves.
shandalo is offline
post #3 of 5 (permalink) Old 05-02-2019, 03:32 PM
TSXXXX's Avatar
K series manual trans are notorious for second and third gear grinds. Likely worn synchros and sleeves.
It is worth making sure the CMC is pushing the clutch fork in all the way - but if it's only second and third gear it's likely those gearsets that are worn.
TSXXXX is offline
post #4 of 5 (permalink) Old 05-02-2019, 07:58 PM Thread Starter
Asanch23's Avatar
It's a brand new slave and CMC so I'm guessing it's it's the syncros
Asanch23 is offline
post #5 of 5 (permalink) Old 05-02-2019, 09:49 PM
Brand new clutch and CMC is all the more reason it should be adjusted for proper travel. Typically after a new clutch install you adjust it before break in, and at least once after break in, if not a third time after another 1000 miles or more. I had to adjust mine before and after break in and again after about 5000 miles. Has this been done? If you haven't and it is out of adjustment you are causing more strain and wear on the transmission internals by not having your clutch disengage fully. In other words, you could be killing your synchros by not adjusting your clutch pedal properly.
shandalo is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
You may post new threads
You may post replies
