Upgrade your rear brake for cheap $$$ - Page 2 - Acura TSX Forum
 2Likes
post #16 of 29 (permalink) Old 04-19-2017, 06:46 AM
I use a personal development adapter
Click image for larger version
dinoc likes this.
eugen19 is offline
Sponsored Links
Advertisement
post #17 of 29 (permalink) Old 04-19-2017, 05:54 PM
1flytsx's Avatar
Thanks but don't see it online for sale, do you have a link to the part?
1flytsx is offline
post #18 of 29 (permalink) Old 04-20-2017, 03:57 AM
I designed and manufactured them myself
If you also want I can send you 1 set
Write me information for delivery
eugen19 is offline
post #19 of 29 (permalink) Old 04-20-2017, 03:58 PM
dinoc's Avatar
Great job!
Sent from my HTC 10 using Tapatalk
'07 Euro Accord CL9 Type-S: Mugen Quick Shift, Alutec strut-bar, H&R front and rear anti-roll bars kit, A-Spec suspension, JDM Type-S front grille, Wavetrac LSD, FlashPro, littlebo's headers, Comptech Icebox, Hondata IM gasket, P2R IM gasket, J35 TB + larger TB to intake box pipe + IM port matched, Flashpro vittuned
dinoc is offline
post #20 of 29 (permalink) Old 09-02-2017, 01:45 PM
Dumb question which car is cu2.
mhchang09 is offline
post #21 of 29 (permalink) Old 11-06-2017, 12:33 AM
^Im sure you googled it by now but it’s 09-14 Tsx.
I’m going to look into the CU2 rear brake setup.
I spent the better part of the weekend trying to make the Fastbrakes rear brake brackets work with 12.3” pilot/MDX rotor and it did not work out. Waste of time.....
goforbroke is offline
post #22 of 29 (permalink) Old 11-08-2017, 11:14 AM
Originally Posted by dinoc View Post
I know 2 guys did this swap, from CU2 to CL9 - I want it do it also, I'm looking for calipers.
It's a direct swap no alteration needed.
One of the guys has a topic on this here: https://hondakarma.com/threads/ichib...63/live?page=2
lol just for the look?? The front calipers are dual pistons vs single piston on CL9 ... did you read the above numbers to see the difference for front and rear, in size and thickness of the discs??
I see he bolted on the CU2 front caliper with success, but no mention of installing the rear CU2 calipers and rotors.
I found two CU2 donor cars in my area, so I can get the rear brake parts for the swap. I'm just not going to bother if it doesn't fit.
I'm guessing this is you on ebay?
https://www.ebay.com/itm/Acura-tsx-0...EAAOSw~y9ZAcvF
Do you have any pictures of your kit installed with the emergency brake cable? Do you have to modify the stock emergency brake cable to make your kit fit?
post #23 of 29 (permalink) Old 11-08-2017, 12:49 PM
dinoc's Avatar
A friend of mine installed rear CU2 disc brakes using the caliper adapters from Eugen.
dinoc is offline
post #24 of 29 (permalink) Old 11-08-2017, 01:13 PM
I was under the impression that you can use these brackets along with a 305mm rotor from the CU2 and retain your stock 1st gen calipers?
Thats what the ebay ad says as well.
Is the CU2 rear brake calipers bigger then the 1st gen TSX rear calipers? I'm guessing it is, but can't really tell from the diagrams.
post #25 of 29 (permalink) Old 11-08-2017, 01:16 PM
dinoc's Avatar
Yes you are right, the brackets are for stock CL rear calipers to fit the rear CU2 discs.
dinoc is offline
post #26 of 29 (permalink) Old 11-09-2017, 01:12 AM
Cool I was just making sure.
post #27 of 29 (permalink) Old 11-12-2017, 11:56 PM
Garage
Fastbrakes TSX 2004-2008 rear 12" upgrade big brake kit
4piston head fully built, turbo tuff rods, wiseco pistons, sleeved block, IMT TVS1320 SUPERCHARGER, drag cartell crank gear, 4piston oil pump, toda chain and tct, asp headers ceramic coated, aftercooled, customer intake, tundra tb, cte manifold, id1300 injectors, return fuel setup, aem 320lph pump
mechanic408 is offline
post #28 of 29 (permalink) Old 11-04-2018, 02:45 PM
You know, the 04-08 Acura TL rear discs would probably be a direct bolt on, with just the rotor and new caliper bracket:
Rear Discs:
Solid, 11.1 in (282 mm) diameter; 0.35 in (9 mm) thickness
Vs. the TSX 10.2"x 9mm thick rear disc.
Coots is offline
post #29 of 29 (permalink) Old 02-22-2019, 08:01 AM
I've been comparing pictures quite a bit. It LOOKS like you should be able to swap the complete rear brake setup from a CU2 on to a 1st gen tsx. It would just require the rotors, calipers with brackets and e brake cables since the brake cables mount to the caliper differently. Has anyone tried it? My biggest concern is the bracket bolting to the knuckle and the spacing.
Chris Treadaway is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
You may post new threads
You may post replies
