RL Caliper Swap Rotor Question - Acura TSX Forum
post #1 of 19 (permalink) Old 03-06-2019, 11:18 PM Thread Starter
I am considering swapping the RL 4-piston calipers onto my 05 using the Fastbrakes brackets. What are the best rotors to use with this setup? I have seen a few different setups used, such as 350z Brembo package rotors, Maxima rotors (which years?), Genesis sedan rotors (which ones?) as well as MDX rotors (which ones?), and I don’t know which ones are compatible. Any help would be appreciated. Thank you.
ETX_TSX is offline
Sponsored Links
Advertisement
post #2 of 19 (permalink) Old 03-07-2019, 02:05 PM
TSXXXX's Avatar
Fastbrakes brackets will require the 12.6" Maxima rotor. Not sure years.
The Fat Four Customs bracket (which I went with) uses the 12.8" brembo-equipped 350z rotor.
TSXXXX is offline
post #3 of 19 (permalink) Old 04-17-2019, 01:34 AM
circuitsports is offline
post #4 of 19 (permalink) Old 04-28-2019, 08:29 AM
I bought fastbrakes, in instructions included it says
08-13 maxima rotors or 350z w brembo package rotors ..
Maxima rotors will fit calipers better but pads will stick above rotor 2mm.
Brembo rotors fit pad better but will require some slight opening of inside caliper.
Im not finished with install but I did dremel inside caliper a bit since there was rubbing.
john666 is offline
post #5 of 19 (permalink) Old 04-29-2019, 11:58 AM
bingo, I would go with a different kit if you can. because the pads stick over the rotor slightly, I'm getting a wild brake squeal.
I had issues fitting the 350z rotor and I'll probably sell my fastbrakes kit and switch to the fatfour customs bracket
mathlabs is offline
post #6 of 19 (permalink) Old 04-30-2019, 08:24 AM
$350 is a lot of money for something that doesn't quite fit. One would thing for that price, they would have adjusted their design a few millimeters so it fits the rotor perfectly. How difficult is that?
Edgeman is offline
post #7 of 19 (permalink) Old 04-30-2019, 03:16 PM
TSXXXX's Avatar
Did you get an old kit? Those instructions are dead wrong and I believe fastbrakes has corrected this to read what it should say:
I promise you - if you go FFC customs you want the 350z brembo equipped 12.8" rotor.
If you go fastbrakes you need the 12.6" Maxima rotor.
TSXXXX is offline
post #8 of 19 (permalink) Old 04-30-2019, 08:45 PM
Yea I bought my Fastbrakes kit from Marcus a couple months ago; the intstructions are explicit in saying that you can use 350z rotors, but you may have to clearance the caliper by shaving some of inside of the caliper. I should've did more research, because had I known that I would've just done the FFC kit.
mathlabs is offline
post #9 of 19 (permalink) Old 05-01-2019, 11:22 AM
TSXXXX's Avatar
I too was leaning towards fastbrakes (more reputable to me than FFC) but my research pointed me towards this issue and I wanted to use the larger rotors so FFC was my choice.
TSXXXX is offline
post #10 of 19 (permalink) Old 05-01-2019, 01:55 PM
Bought my kit last month from heeltoe, just brackets and rotors on ebay to save afew bucks.
I was about to go with
Big Brake Kit 324x30mm + Brembo ? front axle Accord VII/VIII | K-SYSTEM.pro
(if you go with them order without rotors to save on shipping since they are located in poland)
and get a brembo caliper that uses lancer pads I believe but I went cheapest route to be honest.
john666 is offline
post #11 of 19 (permalink) Old 05-08-2019, 11:05 AM
confirming, the FFC caliper brackets fit the 350z rotors without a problem. I switched this weekend from the janky Fastbrakes brackets to FFC.
Fastbrakes only fit the maxima rotors, but I was getting a wild brake squeal. I couldnt find out why, but upon pad inspection, the top 1-2mm of the pad wasn't making contact and probably causing vibration because it was touching the top outer diameter of the rotor.
mathlabs is offline
post #12 of 19 (permalink) Old 05-08-2019, 12:38 PM
TSXXXX's Avatar
Glad you got it all sorted out!
TSXXXX is offline
post #13 of 19 (permalink) Old 05-14-2019, 03:01 PM
Originally Posted by casseverhart13 View Post
Spot on with this particular write-up, I truly think this website needs extra consideration. power washing
spam.
mathlabs is offline
post #14 of 19 (permalink) Old 05-14-2019, 06:03 PM
TSXXXX's Avatar
spam.
this site is getting bad, tons of spam profiles linking to clickbait everywhere smh. Are there any active moderators anymore?
TSXXXX is offline
post #15 of 19 (permalink) Old 05-15-2019, 12:47 AM
I don't get it, I put a link in a post and it said it had to be approved by a mod before being published and it never was published. A spam bot can post links though.
Oats is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
Similar Threads
Thread Thread Starter Forum Replies Last Post
Trans swap. Letho 1st Gen - Engine, ... 2 12-21-2018 04:28 PM
JDM KA24A2 swap? prorider17 1st Gen - Engine, ... 0 10-25-2018 05:43 AM
Is brake caliper service necessary? Jancen 1st Gen - Problems and Fixes 1 12-14-2017 09:49 AM
You may post new threads
You may post replies
