Tony Jackson's Street/Track TSX Build - Page 27 - Acura TSX Forum
 232Likes
post #391 of 416 (permalink) Old 04-19-2019, 02:12 AM
Damn I like the new look. Cohesive and factory-ish. Looks like the recently-announced PMC edition cars!
04 TSX AT
My build thread - Comfort Sport Build
Engine
Phase 1: CT-E I/H, 06 air tube, 06 CAT, reflash
Phase 2: 06 intake cam, 45 VTC, RSP IM, FlashPro
Phase 2.1: HFC, 06 RBB IM
Phase 3: ASP header
Others
Tein CST 8-5 kg/mm with revalve, Progress RSB, Alutec strut bar
Skunk2 Front upper arms
XLR8 BBK (ST-41 4-pot caliper/SS line/One-piece slot rotor)
sonyfever is offline
Sponsored Links
Advertisement
post #392 of 416 (permalink) Old 04-22-2019, 12:20 PM Thread Starter
tr3flip's Avatar
Thank you! I got the other side completed with the painted handles and super happy with how factory it looks while hiding the chrome.
I made time last week to pull the front lower arms off my old TSX (owned by my coworker now) with the PCI spherical front bushings.
I swapped these over on Friday and pleasantly surprised by the difference. The front steering feels more crisp and there is a slight raise in NVH at high speeds over road imperfections and lane reflectors but still very tolerable.
The arms I took off had relatively new TL-S front bushings I pressed in. Upon inspection, these bushings had already started to rip on both arms! After seeing this, I'm even more convinced to keep the PCI front bearings in.
tr3flip is offline
post #393 of 416 (permalink) Old 04-22-2019, 03:11 PM
TSXXXX's Avatar
Wow can't believe the TL-S are ripping already too. I'll have to keep an eye on my hardrace bushings and if they tear the PCI sphericals are gonna make their way on.
tr3flip likes this.
TSXXXX is offline
post #394 of 416 (permalink) Old 04-23-2019, 08:27 PM
J-Spec
Brock's Avatar
For the record, I'm the person that got PCI to make those spherical bearings for a TSX.
I even sent Brian my old control arms. I think the selling point was that the same parts
could be used for three different chassis. Anyway, they work well, but after having them
in for a week, I decided that the crisp steering response wasn't worth the extra road noise.
Just my preference.
Also, the 04-06 TL bushings are harder than the 07-08. Acura went softer for the 07-08 TL.
I have a press release stating that all the suspension bushings were softened up, with the
exception of the Type-S shock bushings in the top hats. Those are harder and also have
the washer molded into the part.
tr3flip and TSXXXX like this.
Brock is offline
post #395 of 416 (permalink) Old 04-24-2019, 10:40 AM Thread Starter
tr3flip's Avatar
Just my preference.
Glad he did! I didn't like them at first when I put them in two years ago but I also think my spring rates and ride heights were way off. Made the whole car feel like crap. I'm enjoying the crisper steering and braking now that I've put them back in.
mathlabs likes this.
tr3flip is offline
post #396 of 416 (permalink) Old 05-17-2019, 01:48 PM Thread Starter
tr3flip's Avatar
Wheel Bearing/Hub/Stud Replacement:
I started getting a wobbly wheel bearing recently so I bought new hubs and bearings to press in along with a new 15mm Eibach wheel spacer kit and extended studs (included in the Eibach kit).
Pressing everything out and back in was pretty straight forward but will admit it took me some time to get everything stacked up right. It's a good feeling knowing that I can swap this stuff in my garage any time now moving forward.
Our son is getting to that age and showing an interest in cars...finally! So I had him help me with the stud replacement and knuckle swap. He seemed to enjoy the work and was able to get everything together once I showed him how to take it all apart. I think I might have myself a new pit crew mechanic for when I go to the track next.
Throwing in this cool shot my friend Danny (JDMzipties) took while he was visiting Eibach the other day.
sonyfever and TSXXXX like this.
tr3flip is offline
post #397 of 416 (permalink) Old 05-17-2019, 05:30 PM
TSXXXX's Avatar
Awesome info here Brock, thanks for sharing.
Originally Posted by tr3flip View Post
Is that last insta pic showing the car post extended studs and spacers?
Looks like you made quick work of the hub/wheelbearing install. Glad to see you had no issues putting a bearing in backwards like my local shop did to me recently lol.
tr3flip likes this.
TSXXXX is offline
post #398 of 416 (permalink) Old 05-17-2019, 05:57 PM Thread Starter
tr3flip's Avatar
The IG photo does have the extended studs and 15mm wheel spacer installed but they were the old knuckles from my silver TSX. I just put these on two weeks ago. I realized the bearing had started to wobble so I had ordered the parts shortly after putting in the knuckles.
And there's definitely a certain way to install the bearings without messing anything up. Just have to be very thorough and take your time.
tr3flip is offline
post #399 of 416 (permalink) Old 05-28-2019, 04:57 PM Thread Starter
tr3flip's Avatar
Update J35 Throttle Body Install:
I picked up a J35 throttle body from an 06 Acura RL at the local pick-a-part. Since my K24 is from 2004 it comes with the smaller 60mm throttle body. The J35 throttle body has a 65mm opening at the plate which is substantially bigger than my stock and still fits into the factory intake tube.
I didn't get any pictures of the install before because this was way easier than I expected. I'll likely go back and port my RBC manifold and get some detailed shots of what's needed.
My initial impressions are good. The car has more torque and little bit more horsepower based on my ass-dyno. It sort of feels like it picked back up the lost torque from swapping to the RBC manifold. A well worthy install for under $100!
TSXXXX likes this.
tr3flip is offline
post #400 of 416 (permalink) Old 05-28-2019, 07:27 PM
J-Spec
Brock's Avatar
I see you got rid of the A/C. I couldn't live without it.
You need the rest of the engine to go with that throttle body.
Brock is offline
post #401 of 416 (permalink) Old 05-29-2019, 02:15 PM Thread Starter
tr3flip's Avatar
This TSX came without AC when I got it and at this point I plan to keep the car more track focused so will likely leave it out. I have an E91 wagon which has AC of course that I use when going out.
A J35 or J37 in this car on track would be awesome!
Brock likes this.
tr3flip is offline
post #402 of 416 (permalink) Old 05-29-2019, 03:21 PM
TSXXXX's Avatar
Did you go with a thermal TB gasket? Is that why I spy a P2R sticker?
tr3flip likes this.
TSXXXX is offline
post #403 of 416 (permalink) Old 05-29-2019, 04:59 PM Thread Starter
tr3flip's Avatar
Yeah, I went with the thermal gasket because there is a section of the throttle body that is exposed on the RBC manifold. The thermal gasket seals that opening shut. The P2R sticker is for the Map to Vacuum adapter on top of the throttle body since the Map sensor is already on the RBC.
There wasn't a whole lot of info on this that I could find but did come across this good photo of the two parts I ordered from P2R to use with my J35 TB.
tr3flip is offline
post #404 of 416 (permalink) Old 06-04-2019, 03:07 PM Thread Starter
tr3flip's Avatar
Needs a slick top conversion...
Brock likes this.
tr3flip is offline
post #405 of 416 (permalink) Old 06-04-2019, 03:48 PM
J-Spec
Brock's Avatar
Do you mean a roof without a hole in it? These cars definitely look better without a hole.
tr3flip likes this.
Brock is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
You may post new threads
You may post replies
HTML code is Off
