1 - 2 of 2 Posts
So I have a 04 tsx 6 speed and I can't put the shifter into any gear without forcing it. Even when it's turned off I can't move the shifter. I replaced the shift cables but it's the same. Shifter box seems ok when it's not on cables. I installed a CT short shifter about 3 years ago so I don't believe it could be that. I can turn car on fine and don't hear any grinding from clutch. I replaced it about a year ago. Any help would be much appreciated.
Base on what you're saying, I suspect the problem could be with your clutch hydraulic system or the throw out bearing itself. If I were in your shoes, I would check the following:
  1. First go underneath the dash to see if your clutch pedal isn't cracked.
  2. If that checks out fine, try bleeding your clutch slave cylinder.
  3. If that doesn't help, issue could be your throw out bearing going out. Had a similar issue a couple years ago and replacing the clutch and throw out bearing solved the problem.
If you have issues with a creaking clutch or pedal being stuck to the floor, then you would likely need to replace the clutch master cylinder.
1 - 2 of 2 Posts
