The cold weather has started in Michigan... and only one side of my heat/AC controls is functioning properly. The drivers side does not blow heat when the temp is turned up - but the other side works perfect.
I got underneath the dash and removed the blower regulator - because that is what is NOT moving/opening the baffles when it should. I took it apart and tested it on the bench, everything works fine. I took off the power transister, took it apart and tested it - no problems there. I knew it wasn't the transister because the heat is blowing hot on the passenger side. I've tried everything I can think short of taking it to the dealer and having them destroy the car...
Has anyone had this problem or have any more ideas?!?
Thanks.
Thanks.
