Hi,
I'll try to be detailed enough for some good ideas here.
2 months ago I got an 04 TSX from a buddy with 238k miles.
When I got it:
1. He told his mechanic said it's okay to use 87 octane fuel. He's been doing this for 2 years approximately. For the last 2 fill ups, I switched back to 93 octane and plan to keep it that way.
2. His mechanic told him the connector for the TPS sometimes gets loose and will cause the RPMs to fluctuate, sometimes roughly. Told me to make sure it's plugged really snug and tight.
3. RPMs constantly fluctuate even to the point that it almost feels like the car downshifts several times during a usual 15 to 20 drive. Now it seems to happen even more.
4. A Crack in the air hose between the engine and air filter (where the mass air flow sensor goes) is taped with electrical tape.
5. Top gun mechanic friend of mine says it sounds like the car is burning lean. (In a Facebook message because we no longer live close enough for him to see it in person)
After I got it:
1. 3 weeks into owning it I get a misfire code and the misfire made it run crappy of course.
2. I replace and gap all 4 plugs and 1 ignition coil.
3. 2 weeks after fixing first misfire, another misfire made me need another ignition coil.
4. The same day I replaced the ignition coil I began getting to P0420 code that mentions "low threshold" at B1 (bank 1 -what is this?).
5. It's running exactly as well as it was the day I got it, except the RPMs fluctuations and making it feel like a downshift kinda, at times.
6. I ran a can of cat cleaner through and still have the engine light for the P0420 code.
I have maybe 100 bucks right now to spend on the car. However, soon I will begin putting a little more money in it to get it running tight.
Any suggestions would be great. Thanks in advance.
When I got it:
After I got it:
