1 - 2 of 2 Posts
I have an Acura TSX, 2.4 vtex with 148,000 miles. Last week driving home and it completely shut off as I stopped in the median. Would not crank back up, when out the pedal to the floor it will try to run, but super ragged, and rough, while engine shaking. After diagnosis, it was low on oil, so complete oil change has been done. It has oil pressure, still, and has fuel (have volume, not sure in pressure). The only code that is up is cam shaft position sensor. This code has been a constant on my car, replaced the sensors a year ago, and I replaced them again this weekend. Still will not crank. I am leaning to the time chain has skipped a tooth and the subsequent result putting car out of time.
Has anyone had any issues like this? Am I correct in going to timing next, and relaxing chain and tensioners???
Thanks for the help
1 - 2 of 2 Posts
