So about a month ago I hit a deer on the interstate. My poor baby sustained about $6k in damages which included the driver's side headlight and everything behind it. They told me that they had to re-wire the headlight because the wiring harness was pretty badly damaged but reassured me that they had an Acura tech do the job. I was out on the freeway during the daytime and attempted to use the flash-to-pass and noticed that the HIDs fired up along with the high-beams. I have never noticed this before and in fact I am almost certain that when the headlights are off and you pull the flash-to-pass switch, only the high beams should flash. Can anyone confirm this for me? As in, can you run out to your car and check it out?
I am looking over the wiring diagram but it isn't clear what should occur since the "control block" and "combination switch control unit" are depicted as black boxes. Thanks in advance!
