Never had a problem with my car until recently. Started up the car and the cel light and the triangle light came on.
I looked up the code which was P0341.
Some people have recommended replacing the timing chain, another said to replace a sensor and another mentioned replacing the VTEC actuator.
I'm not sure what to do but the car has 120k miles and it runs fine. I don't have any power loss that I know of as it runs exactly the same as when I got it in 2008. The only other issue is its leaking some oil but I'd assume that has nothing to do with it.
I reset the code with an OBD II scanner and as soon as I turn the car on the CEL kicks back in.
If the chain were skipping would it be a loud noticeable noise or would I have to really listen to hear it? I'd assume a chain skipping or grinding would make a very noticeable noise.
Any help would be appreciated.
