1 - 2 of 2 Posts
06 TSX Help!
Hi, New to the club, please forgive newbie mistakes! :smile2: I could really use some advise if anyone could assist!
I have a 06, 6 speed, about 2 years ago in a bad storm my tires were spinning in a lot of rain and POP! The VSA light came on and traction control ceased working. Checked the switch, fuse, etc. VSA light and triangle come on all the time now, cruise control doesn't work, but no check engine light. I have 109k now, this happened at about 98k, I had the clutch replaced at about 100k. I am now scratching my head wondering if the shop could have fixed the VSA at the same time as the clutch replace? (not sure why I am thinking of this now, feel a bit stupid :frown2:
A couple weeks ago my car died while a friend was borrowing it. I found that it would run (barely), VERY rough and wouldn't idle at low RPM, just sputter out. Took it to the same shop and was told the car had been 'beat on' and he thinks its a timing issue. He didn't want to work on it which was odd. Another mechanic found that the timing chain had 'jumped' and re-aligned the sprockets? This did the fix, but he told me not to drive it until he replace's the timing chain. I was quoted $400 for labor and $200 for parts (including an oil and filter change too).
Could the VSA been addressed easier at the time of the clutch replace? I notice lots of folks having/had VSA issue's, but after scouring many threads, never found a solid solution? h1e1l1p
Just curious to know why you say the traction control ceased to work? How did you determine this yourself?
The triangle warning and VSA symbol coming on could be a couple of reasons. This was happening to me intermittently for a few months and I followed the reset instructions found on this forum on several threads, one of them being this one:
http://www.tsxclub.com/forums/1st-gen-electronics/31353-error-code-84-vsa-sensor-neutral-position-memorization.html
This only worked temporarily. At the end, what fixed the issue was a wheel speed sensor replacement.
Replacing the clutch and fixing the VSA are two different "repairs" but they could have been done at the same time if that's what you're thinking of. Keep in mind one repair has nothing to do with the other.
1 - 2 of 2 Posts
