i had a thermostat go bad on my daily and it stayed at 0 or Cold and never moved. I'm assuming that the needle goes back to Cold/0 when the car is turned off.Sounds like a stuck thermostat. Check that first and report back![]()
+1. They can fail either wayI've seen thermostats both open and closed. If the water pump is ok, I would look into the thermostat
Good point also.. Have the cap pressure tested before you do the T stat. If it does not hold the pressure it's rated for, the cooling system won't work properly.I am hoping it is something simple. I plan to change rad cap, thermostat, and the coolant. I would like to not change the water pump. The thermostat looks a little challenging.
