Not common at all on the 1st Gen TSX's.
Is the CEL on? Any DTC's?
I would connect an OBDII scanner to see if the scanner can read engine RPM's from the ECU.
If the OBDII scanner can read RPM from the ECU, that likely means the issue with with the tach in the gauge cluster.
