1 - 18 of 18 Posts
Triple Platinum Member
Cam spec:
246 duration at 1mm lift and .465 lift measured at the valve with no lash
Thank you John Grudynski @ HyTech!
....its fate....
It would be interesting to see how the 09 cams compare with the 06.
Im sure he'll have it tuned, otherwise cant advance the cam timing.
Did John mention how the 09 cams would compare to say his spec 1 cams or any other DIC's for that matter?
I love the roll with sake!!!! Oh cams look good too...JK
What are the cam specs comparing the 2009 TSX K24 intake cam to the prior TSX K24 intake cams?
flashprroooooo!!!
good stuff. you should at least try to get it edyno'ed with vitviper. what fun is it to have it installed if you don't know the gains?!
Discussion Starter · #12 ·
I'll dyno once my quad rotrex build is done...
Yeah definitely interested to hear how this compares to using the 06 cam. Hit me up sometime when you get a chance I would love to hear how your project you have been working on is coming along. :)
1 - 18 of 18 Posts
