41 - 52 of 52 Posts
I have the usb dongle, and was able to get Apple CarPlay to work.. Although my unit froze when I was driving, and now GPS doesn't work. Unit does not go into standby mode any more, takes forever to boot up when I start the car.
Trying to get the original firmware but no response from Aliexpress.. I'm wondering if enough of us complain, we can get at least the original firmware or something from them.
I believe it is a joying unit under the hood. My only fear is that since it has the A/C controls, that the joying update my kill that and A/C controls no longer work
Good to know...I'm still gonna hesitate on buying for now please keep us updated
just recieved mine from amazon today. its the 2g +32g android 8.1 version. but im having some issues installing it . i cant find any sort of manual or videos on what the extra wires go to or how to connect the blue light you move over from the original radio along with the vents. ( ive seen where one guy had a blk and red wire hanging out from his that MAY have been to power the light but he wasnt sure either, and mine doesnt seem to have a blk and red wire at all. also there are at least 2 unused plugs on the back( what are they for? ) and a couple short white wires with no ends that MAY be to power the backup camera? who knows. also i found a micro sd card slot on the back / bottom of the unit but i dont know if thats for a sim card or a sd card slot for updates, or just extra storage. its kinda maddening that it didnt come with ANY paperwork or guide at all. has anyone installed one that can give me some idea ?
its been a while but let me chime in , I went in on the FB Group Buy for the android 10.2" screen unit and paid ( i think ) $460 or $465 , I was in the 2nd batch , Install was a breeze but thats about the only thing thats good about this unit. Like john666 mentions HVAC touch controls are lagging and are displayed in Celsius instead of Fahrenheit which makes it a little less forgiving in temperature as you so you are adjusting the temp by almost 2 degrees F with every click, say you start of on 56F then its 58f, 60f ,62f ( even though its only showing you 1 in c adjustment ) its kind of annoying and i think inaccurate because the temps seem to be all over the place really. not only that but when you are going up or down on temp adjustment it skips temps for example if i start of at 21c then go up to 22 then 23 then it will lag when i press up it will show 23 even though its 24 then it will skip 25 again and then it will show 26 so it dosnt display temps between 24-25c. thats one issue , second issue is the unit is generally slow and not very accurate when youre trying to control it while in the driver seat driving. Another issue i was having was with a GPS app called WAZE , gps would work fine for about 25-30 minutes then would freeze up , now you have too reboot the whole thing while youre driving and go through the process of typing in the address again to get the GPS back on track , not a fun thing to do. Ive had the unit kick me out of apps and freeze several times especially while using Pandora and YouTube. Sometimes it just kicks me out of them to home screen , other times it reboots completely ( android boot screen ) One of my biggest dislikes is the hot spot connectivity. I connect the unit to my iphone 7 plus with the personal hot spot option so i can have internet radio , it works fine , as soon as i turn the car off and get out of the car to say pump fuel or run into a gas station or what not the connection is gone and i have to go through the pairing process all over again. Also the radio bezel feels out of place due to the fact the matching woodgrain/steel trim part is black, if it were fully functional unit and didnt have so many issues i wouldnt mind the trim color but with all the issues that this unit has and the price you have to pay for a non functional android headache you are better of saving that money and doing a double din NOT A CUBBY HOLE hole install with a quality brand name touch screen headunit.
~De5
it sounds like you got a bad unit ,mine works fairly flawlessly. slight lag when turning up/down the temp but not much. and you can add a app to your phone that sets up a job to auto connect whenever your phone sees the radio . the unit sounds really good is DPS and has tons of equalizer and sound settings (like 4 or 5 screens worth ) my waze and google maps app works perfectly ( may want to check your ant. connection or reset the unit) the only issue i have with it is the loss of my dash temp (but i did find a way to reconnect that with another thermistor ) and that its in celcius but you just double the number and add 30 or something to get Fahrenheit . i also started using the agama launcher from the play store which is awesome and has a lot of cool features and has a lot of customization . and i have a obd2 bluetooth dongle in my car so it can show all the engine output faults ect. in real time i love mine . ...except for that damn celcius thing !
found this video but it has mix reviews on Amazon
I have this 4G unit for half year with Intel SC9835i CPU + 4gb ram / 64gb storage + dsp, the sound are pretty good by DSP processor + 16 levels EQ, and running on Android 9 smoothly.
but i am greedy to sold it to change a newer - PX6 CPU with 4gb ram / 64gb storage + 1280 x 800 display + DSP decoder + op amp
it still Androiod 9 and i feel no different in response speed, but the sound get improved, more clear and powerful bass, can say i loved it more.
Where did you find that unit?
TSX android radio hits the eBay market.
https://www.ebay.com/itm/Android-6-...-DVD-Player-For-Acura-2004-2008-/282777001285
Specs:
Version: Android 6.0 System
CPU:Quad Core4
RAM: 1+16G
Resolution: 1024*600
Display:10.1 Inch Capacitive Touch Screen
Internal: only Support WIFI Hotspot
GPS: Support Most of Android Map/ Dual Zone While Navigation Can Listen Music/ Baud rate: Support 4800-115200
Phone Link: Support Two Way Control For Android Phone ,One Way Control For Iphone
OBD: Support OBD II (below 3.0 version)(OBD Plug Is optional)
DVR: Support External DVR
Radio: Amount For Stations Saving:30 (FM 3*6, AM 2*6)
Video Format :AVI, H.264, VC-1, MPEG-2, MPEG-4, DIVD, DIVX, Real8, 9, 10, RM, RMVB, FLV, MP4, M4V, VOB, WMV, 3GP, MKV
Audio: Format : MP3, WMA, FLAC, AAC, WAV,APE, OGG, MP2, 3GP, MA4
Max Audio Output : 4 X 45W
Image: JPG, BMP, GIF, PNG
What about climate controls?
So is this unit worth buying?
I know this is an old thread but the answer is NO. Don't buy these Chinese pieces of junk. I really wanted a system because I finally got the parasite drain from my bluetooth and had to disconnect it. I ordered the most recent unit from AliExpress back at the end of August. Everything seemed to go well but it was summer and I usually blast the A/C. One night it was a bit cooler and I set the temp to around 73. I didn't notice it warming up and was still really cold air. After I arrived home I got my temp gauge out and ran one side on Hi and the other zone on Lo. The Hi side was only blowing out 55F. Our stock OEM units under the same setting would blow out hot air at 110F. There are also other issues where it pulls outside air in even though I have it on circulate (no auto setting). Other times I've noticed that say for example I have have front vents and floor on, it randomly goes to defrost and floor. I usually have the temp set around 73F but that just feels way too cold with this HVAC control system.
On the radio side there are also issues.
The door indicator sometimes does not go off when you open a door and close it.
The climate control goes on randomly even though you aren't touching the climate controls.
Waze randomly flips the screen thinking you are going in the opposite direction and then flips it back again to the correct driving direction
The mirror application sometimes disconnects, when this happens you have to either shut down and startup your car or reset the radio
Volume button down sometimes raises the volume instead of lowers it. This seems to happen and stay on random startups of the car
I could probably live with all of the glitches on the radio. The A/C is just a dealbreaker for me. Also note that if you buy this from AliExpress the seller is going to want the unit back and shipping it back is on your dime ($70-100) regardless of showing proof of the defect like I did. AliExpress would not force the seller to pay for a prepaid label. I was able to luckily get my credit card company to file a dispute. I really don't care if AliExpress will sell me any other products because I am never taking a chance on something this expensive ($425) and getting stuck with a terrible product.
I updated the MCU (HVAC firmware 11-2022) with no success. No firmware was available to the radio unit (FW dated August 2022). I hope I have convinced anyone reading this in the future to just avoid these units. If you want a system I believe getting a double DIN with the Metra HVAC controls is the only way you should go besides keeping the OEM unit.
41 - 52 of 52 Posts
