1 - 2 of 2 Posts
So I’m building a my tsx k24 motor and came across this 2.6l stroker kit. It seems to be a good decision because it comes with a crank, robs, pistons, wrist pins, bearing and piston rings that are already balanced. Im planning to make 500-600 HP with a complete Ferrea head. My question is, is the stroker kit worth it or should I piece the bottom end together myself and remain 2.4l
I don't think a 2.6 is worth it. you can easily make 600hp on standard crank with rods and pistons. I believe the stock bottom end limit is 350-400wtq so depending on turbo you can get to 500hp all stock. Just get drop in pistons and upgrade your rods and youll save a ton of $$ while reaching your goals.
1 - 2 of 2 Posts
