2004 TSX
The doors on my TSX will not lock/unlock using the driver side lock button unless all the doors are closed and the key is in the “on”position. It appears that the multi switch in the driver door doesn’t get power (not illuminated) until the key is “on”.
I have reprogrammed my fob several times. The fob doesn’t unlock or lock any of the doors/trunk. The only thing that I can get the fob to do is set off the panic alarm.
I attempted to use a driver door multi switch from a 2005 tsx, and the plugs were different.
Does anyone have a suggestion or has anyone dealt with this issues before?
