Hi all - strange issue that I hope someone can help me troubleshoot (without taking it in for service to pay an arm and a leg).
I don't drive my 2004 TSX very often and the last time I attempted to start it, the battery was almost totally dead and wouldn't even start with a jump. When I attempted to jump it, the rear passenger window went down on its own. I honestly don't know how or why that happened but it did.
Anyway, I replaced the battery with a new one and everything seemed to be fine, except the rear passenger window did not go up - not from the driver main control or the control on door itself. I can hear a click when I use the window switch but it doesn't budge at all.
I ordered a brand new window regulator motor thinking that was the culprit. I just replaced it with the new part and have the same result - it does not budge. Strangely, the motor gets very hot when I'm trying to get it to work (the old one and the new one). I have everything plugged in but I am leaving the regulator hanging outside of the open door panel for testing, and can hear the electrical current click when pressing the control and the motor gets hot very quickly.
I've tried all of the fuses (moving the four power window fuses around) and they are all fine. I've also tried removing the controller from the door with the bad power window and just use the driver controller, tried removing the driver controller and just use the controller from the door with the bad power window. I've also tried resetting the windows.
Sorry for the long post but hopefully the details show what I have already tried to do and someone has an idea of what else to try.
