2004 TSX automatic with 217K miles original owner radiator fans both work but fail to come unless the AC is activated then cools to normal temp. Car gets regular maintenace and problem started about 2 weeks ago. Today I added coolant. Radiator inside is clean and looks like new.
On the highway the problem does not occur. Only at red lights or otherwise sitting. Turning on AC both fans activate and engine cools right down.
My guess is a temp sensor? Note: the temp gauge on the dashboard works perfectly and there are no check engine lights etc.
Update: I removed and tested the Fan relay and it clicks / tests ok. I checked the Fan Switch aka coolant sensor that is screwed into the side of the radiator near the driver's side and there wasn't any corrosion on the plug and the plug had dielectric grease on it. I couldn't see the pins on the switch itself. Next, I could try shorting the two connections on the plug and see if the fan goes on.
Thanks.
Thanks.
