hello everyone, i’m having a problem with my 2004 tsx it isn’t starting at all. when i put the key in all the accessory lights turn on but once i turn it everything turns off and there is no crank. i’ve changed out the alternator, the battery, the starter, the starter relay, and the ignition switch. still won’t start at all and i’m thinking there could be a problem with the interior fuse box. tested if there was any power going to the ignition switch and there was no power. i’d appreciate any help thank you.
