Get a stethoscope they are not expensive and that way you can pin point the noise more accurately. Sounds like it could be a belt tensioner pulley( the bearing in it going bad).
the water pump is like $103 from acuraoemparts.com.Thank you all. I went to Acura Service center and they said it is Water pump that need to be replaced along with drive belt and antifreeze and will cost $563 + tax...![]()
