Hey guys, when I bought the car it came pre-wired with 4 gauge wiring for the sound system, a signal wire, and a LOC (sorry I forgot the brand) for RCA input off the rear deck speakers.
I got a pretty decent deal on my amp from visions and my the sub and box were a late surprise birthday gift. I have an MTX 12" Jackhammer (JH5512D) and a Pioneer 800 Watt amplifier (GMD7500M). I connected everything properly but didn't inspect the LOC wiring. I assumed it was correct and I was way too excited from the present.
The problem is the sub barely pounds even with the OEM HU set to +6 bass. I've cranked the gain and the bass boost up, turned off the LPF (low-pass filter). I then switched the sub wiring (incase internally it was backwards) and that did nothing.
One solution I found was if I set my balance all the way to the left or all the way to the right the sub pounds. I re-read the owner's manual and pulled this excerpt,
The sub can be ran from speaker level input using the wire provided (RCA on one end and 4 wires on the other). I think the easiest solution would be to use the wire kit provided and run speaker level input but any suggestions for troubleshooting the LOC RCA combination?
"This product is a mono amplifier for subwoofer. If both L(left) and R(right) channels are connected to the RCA input of this product, output is mixed because this product is a mono amplifier."
