1 - 2 of 2 Posts
Hello all,
Having a problem with this darned navigation system. The system stopped working and screen went black along with message "CHECK DISC"
I removed the cd rom drive and ordered a new drive from Ali and installed it. It seemed to fix the problem showing the Navigation screen when car started...I thought Yeah
I fixed it ......Nope once the screen asking to enter navigation code comes up the touch screen doesn't work. I tried everything from you tube and other forums , I can not
enter the code from the numerical screen to unlock ??? Help :unsure:
this video should help you out. He shows you how to get the RADIO serial number, to get your NAVIGATION serial number I found it in the trunk where the CD reader is, it's right underneath it. good luck! also if you can get your radio code to show u might need to unplug your battery and wait a minute and then plug it back in and try again.
1 - 2 of 2 Posts
