Whats goin on everyone new to the site here!
Heres my question i have an 05 tsx with the navi.
Now what i want to do is put in 4 10in subs and amp.... Is there a way to hook the amp up to the stock headunit (navi) with out buying an after market headunit. Please let me know!
Thank you!
Yes there is. But in all honesty if your asking this question, its probably a good idea to go to a reputable car audio shop to have the work done for you. A tsx is way to nice of a car to burn up.
its not hard. all u need is LOC and system wiring kit
I bough dual 13" box but i ended up cutting it to a single 13" jl audio. with jl audio 1000/1v2 amp. power cable went from the battery through there is a Red Colored Hose in the engine bay, take the rubber off and push it through there, then run your cables underneath ur passanger door panel , u should have blue and green cable on that side.You dont need to remove the manufacture radio, my amp ground cable came out like a foot short so i grounded it backseats middle gateway that opens to the trunk , just cutt a little carpet off , sanded it with sandpaper and grounded it there, Used a 20$ LOC ( line out converter) hooked the 2 back speakers on it and used my AUX on the other side and baaam the subs bumping :) REMEMber Thicker Cable is + skinnier cable is -
