1 - 2 of 2 Posts
DaniC
Hi just wondering if anyone knows how to open and access the led bulbs in the:
Switch Assy. - 35750-SEC-307
Switch Assy., Power Seat Memory (L. SIDE) - 35961-SEC-A01
Switch Assy., Remote Control Mirror - 35190-SEC-C01
I plan on changing the colours
46480
Id be hard pressed to tell you to go trough with this as youll likely encounter issues with finding bulbs, getting everything to stay together when youre done and doing the work in a way that will light it up properly. But if you must, there should be little tabs on the assy. body that you can pry back (but will probably break) and seperate the two halves. Good luck feller.
Sent from my LM-V405 using Tapatalk
1 - 2 of 2 Posts
